NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Mon Jan 27, 2014 11:15 pm
Well finally replaced alternator today :D
Compared both together before fitting
Now fitted. Works perfectly, no more Batt light or DTC stored :mrgreen:
Also removed old accelerator pedal mounting bracket
& fitted replacement along with accelerator pedal
Now drivers seat can be refitted :D
Yes, I know clutch/brake pedal could do with new rubbers :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Tue Jan 28, 2014 7:37 pm
Fitted new seatbelt clasp for belt minder to drivers seat before refitting seat.
Along with steering column covers & O/S kick panel etc
Think I will do away with old grey kick panels etc as they don't look right with dash. Time to get later dark pewter ones.
I may also change floor cover to dark pewter as well :?:
Still looking for replacement door cards to match dash :(
paul2012
Postby paul2012 » Wed Jan 29, 2014 6:49 pm
Routed wiring for ext ambient air temp sensor through engine bay. - Sensor clips onto back off lower bumper reinforcement bar :wink:
Now it's working as it should do & get this message & chime when air temp is 4°C & below. Simply hit menu set/reset to clear message.
Yes ABS light is on, due to ABS pump not plugged in yet, I really need to fill tank with diesel :roll:
Just an idea on what it looks like in the dark - yes they all can be dimmed including stereo via dimmer control on headlamp switch :wink:
paul2012
Postby SteveO » Wed Jan 29, 2014 8:45 pm
So Paul are you keepig a running cost of what the project is costing as you go along?
SteveO
Postby paul2012 » Thu Jan 30, 2014 4:05 pm
SteveO wrote:So Paul are you keepig a running cost of what the project is costing as you go along?
yes I am 8)
paul2012
Postby paul2012 » Sun Feb 02, 2014 7:42 pm
Well changed Pollen filter today.
Old one looked as if it be in there for a few years :roll:
Replacement grabbed from ebay here :arrow:http://www.ebay.co.uk/itm/FORD-CONNECT- ... 3a8ad92da3
Also bagged door handles from local salvage yard. Going to get them painted up before fitting.
To save on time, due to complete door lock assembly on front doors has to be removed to get access to T20 torx bolt.
It works out easier to get another set. When painted, I can remove my old ones then fit replacements straight away.
Then get old ones painted & sell on ??? 8)
paul2012
Postby Milemuncher » Sun Feb 02, 2014 10:14 pm
Paul, the pollen filter looks like the one that was in my Dad's (ex-police) Astra. He wondered why the car was permanently steamed up. Removal of the offending item was an instant cure (non-ac vehicle)
Strangely though our Connect came with no filter (i assumed it was required with ac) it had a plastic grille fitted in its place, i guess to minimise leaf ingress etc. If i had seen your photo Paul, i wouldn't have spent 15 mins trying to wedge the filter in the grille thingy when it was obvious it was one or the other !
Milemuncher
Postby paul2012 » Sun Feb 02, 2014 11:00 pm
After a few PM's Here is the resquested info on how to enable auto wipe/headlights with alarm on 2009 onwards connects
Parts required
Rain/ light sensor with plug & lengh of wiring - part no - 3S7T-17D547-AB
Rain/light sensor bracket/covers part no's F1488557, F1710216 & F1687666
headlamp switch with auto lights - part no 4M5T-13A024-DA
GEM module (MUST have CTM CL RKE AS on label) Part no 9T1T-15K600-ED
Antiptheft horn part no 2T1T-13832-AD
Bonnet switch part no F3553259
Rain sensor wiring details
Pin 1 on sensor connect to Pin 8 on headlight switch
Pin 2 on sensor connect to GND
Pin 3 on sensor connect to GEM connector BL pin 22
Autolights wiring details.
Pin 4 on headlight switch connect to GEM connector IPR pin 21
Alarm wiring details
Anti-theft horn connect to GEM connector IPL pin 1
Pin 1 on Bonnet switch (hood ajar) connect to GEM connector BL pin 23
Pin 2 on bonnet switch connect to GND
GEM programming instructions Ford IDS required.
Before connecting VCM/VCMII to vehicle.
Unplug GEM module.
disconnect toughbook/laptop from internet & then run IDS (by disconnecting from internet, IDS can't download vehicle's "As Built Data")
Once IDS has communicated with vehicle. Select Module programming & then Programmable module installation (PMI)
Select GEM, IDS will attempt to download "as built data" it will then give option to manually configure GEM module.
Select manual configuration & enter the following codes when instructed too. ( there are 3 programming codes to enter in - 1 at a time, shown in yellow box below)
Once done IDS with ask for module to be installed. At this point plug GEM module back in & follow instructions on IDS to complete process.
Now you have automatic wipers & headlights with Alarm :D
paul2012
Postby paul2012 » Mon Feb 03, 2014 8:54 pm
Milemuncher wrote:Paul, the pollen filter looks like the one that was in my Dad's (ex-police) Astra. He wondered why the car was permanently steamed up. Removal of the offending item was an instant cure (non-ac vehicle)
There should be a pollen filter there with or without AC
To replace, remove scuttle panel, then remove 2 torx screws securing water tray & remove it. This will give you easier access.
Unclip flap at front of pollen filter housing, then lift & remove grille/mesh then remove pollen filter.
Reverse proceedure to fit new filter.
(My Connect is missing the plastic grille/mesh that goes on top of filter. Currently have a new one on order Ford part no F4529629)
I can say that there is an increase of airflow now filter has been replaced :D
paul2012
Postby Milemuncher » Mon Feb 03, 2014 9:40 pm
Tried all combinations of fitting the grille back on with the filter in, to the effect i deduced it was one or the other ! In anycase i cant see an issue now as the filter is tight fit, and can't fall out
Milemuncher
Postby paul2012 » Tue Feb 04, 2014 7:23 pm
Having a clearout on connects parts :!:
Will be listed here :arrow: viewforum.php?f=66 over the next few days.
So if anything you are looking for, let me know 8)
paul2012
Postby paul2012 » Thu Feb 06, 2014 8:01 pm
Time for new tyres 8)
The are 205/50/17 93W XL
Fuel efficiency rating C
Grip rating B
Good price too, £84 for the pair - brand new on ebay
paul2012
Postby liteace » Thu Feb 06, 2014 10:37 pm
Nasty, cheap Chinese tyres, no thanks, is it not best to spend a little more on things like tyres and brakes !
liteace
Postby Milemuncher » Thu Feb 06, 2014 11:01 pm
Tyre discussions cause more heated debates than anything even amongst friends !
I have always been sceptical about budget tyres and never used them, however when my other half bought her Connect sportvan, it came with four reasonably new Khumo tyres on. Everything was done at the Ford dealer by the previous (lady as well !) owner, even down to tyres, bulbs and screenwash purchases ! Anyway, they seem fine, which has surprised me - not noisy, and the grip seems fine.
On the other hand, my work car - a 2011 Octavia - has just had new tyres fitted yesterday, and as it is going back in about 6 weeks or so, I expected the lease company to try and save money, but they authorised all four Michelins. Even with the discount they must get, its an odd decision.
Milemuncher
Postby liteace » Thu Feb 06, 2014 11:06 pm
At least Kumho are listed in the tyre test, those Shengtai rapdis, cant even find them
liteace
Users browsing this forum: DIYvanGUY
