EGR blank tips/help
Re: EGR blank tips/help
Postby Adam_84 » Mon Oct 15, 2012 2:54 pm
Got my ECU back from vantuner on Saturday and wow is all I can say anyone who hasn't had it there's remapped then they are missing out. Also asked about what pipe to blank and its the one with the white line on it the other is speed sensor.
Adam_84
Postby g-man » Mon Oct 15, 2012 3:08 pm
speed sensor is either off g/box or abs
g-man
Postby Connect-rick » Mon Oct 15, 2012 3:25 pm
Adam, which engine have you got?
2006 white 75ps
EGR blank
Sony head unit, vibe slick 6x9 and ripspeed rs132 in front.
Connect-rick
Postby Adam_84 » Tue Oct 16, 2012 12:07 pm
It's the 90ps one on an 05 plate LWB.
Adam_84
Postby Connect-rick » Tue Oct 16, 2012 12:30 pm
Mines a 75, hoping to hit 90+ when it's remapped
2006 white 75ps
EGR blank
Connect-rick
Postby gt_addict » Tue Oct 16, 2012 2:01 pm
Connect-rick wrote:Mines a 75, hoping to hit 90+ when it's remapped
My remapped 90ps hits 115mph and then runs out of revs. That's on my private racing circuit in my garden ;)
gt_addict
Postby Adam_84 » Tue Oct 16, 2012 2:50 pm
You must have a big garden gt_addict lol I'm just happy that it accelerates so much better and it's doing better mpg at the same time.
Adam_84
Postby Poopsie » Fri Oct 26, 2012 7:37 pm
So is it worth me doing this then I have a 08 plate 110 tdci lwb
Sounds a bit crap to me to be honest !
NEED TO GO LOW LOW LOW XXXX
Poopsie
Postby Connect-rick » Fri Oct 26, 2012 9:52 pm
Up to you. The benefit of not circulating dirty used gases back through your engine has got to be worth it. Open your valve and put your finger inside, the muck in there is going back into your engine so can't be good. Mine runs perfect blanked off. It's the remap that counts
2006 white 75ps
EGR blank
Connect-rick
Postby Poopsie » Sat Oct 27, 2012 4:46 pm
So I'm confused as to what one I need, the drilled one or the solid one ?
Also is it worth drilling the air box as I'v just put a k&n in ?
Poopsie
Postby Connect-rick » Sat Oct 27, 2012 4:50 pm
Tddi isn't drilled
Tdci is drilled
As for air box no idea!
2006 white 75ps
EGR blank
Connect-rick
Postby Adam_84 » Sat Oct 27, 2012 5:05 pm
Only TDCI's after a certain year require the hole to be drilled, says so earlier on in the thread thinks its 2006 onwards has the hole drilled.
Adam_84
Postby Mylee » Sun Oct 28, 2012 7:54 am
Poopsie wrote:So I'm confused as to what one I need, the drilled one or the solid one ?
Don't drill the airbox, you need the cold air feed from a focus along with the bottom half of a focus airbox. Drilling the airbox will just let hot air into the engine, exactly what you don't want.
Keep an eye out, I'm from Rochester as well :D
Mylee
Postby Poopsie » Mon Oct 29, 2012 8:56 am
Yeah think I'v seen ure van mylee don't know the name of the road but looks like a barstard to park down there if its where I'm thinking of ! Just looked on fleabay and it don't tell you which one I need how annoying one mentions !
Poopsie
Postby Graham Taylor » Mon Oct 29, 2012 11:32 am
Poopsie wrote: Just looked on fleabay and it don't tell you which one I need how annoying one mentions !
Either get one with no hole and if waring light comes on drill one or get one with hole. Mine is 05 plate and I have one with no hole.
Graham Taylor
