metalworker0 wrote:its here ..in case you cant make it where it is ..liner and wing removed in this photo
see arrow
metalworker0 wrote:in this picture you can see how the liner just about does not cover the hole and the relationship of the tyre and wheel to it as far as splash spray is concerned.
click twice to expand picture
see arrow
metalworker0 wrote:Have you tasted this water ..does it taste sweet....if so, it's from the cooling system
meanwhile
these are ford bulletins on faults from this section of the forum..some are mk1 some mk2 ..it does not say..
viewtopic.php?f=54&t=124877
This all of them !
11/30/09 Waterleaks at the upper windshield
Waterleaks from the upper windshield area with heated windshield, one probable cause is insufficient application of windshield adhesive during production.
To rectify this concern, windshield adhesive should be applied into the gap at the windshield. It is NOT required to install a new windshield.
To enable a smooth adhesive application the grey flat nozzle needs to be reworked
9/6/07 Condensation dripping into the front footwell
Dampness in the front footwell the probable cause is incorrect manufacturing tolerances in the joints of the climate control housing components. This allows condensation to escape from the bottom corner of the climate control housing when the air conditioning (A/C) is operating.
To rectify this concern the climate control housing should be removed and sealing strip applied to the gaps in the climate control housing joint area.
Before carrying out the procedure detailed in this bulletin eliminate all other possible causes for water entry into the front footwell (e.g. water entry after passing through a car wash, during very heavy rain or because of a blocked A/C overflow hose on the bulkhead in the engine compartment). Additionally the A/C system should be tested.
9/14/07 Water ingress in the front footwell/interior and in the loadspace
Isolated instances of the following causes of possible water ingress points in the front footwell/interior have been identified:
A. Water ingress via the drain bore in the water trap or via the windshield (left-hand vehicle side):
Cause: Insufficient or intermittent sealer applied in production between the fender apron panel outer reinforcement and the A-pillar/water trap may lead to water entering into the front footwell. To rectify: Seal the affected areas with sealer. Installing a new windshield and a new windshield glass weatherstrip is not necessary. Cause: Water may enter into the front footwell between the windshield and the windshield frame because of insufficient or intermittent sealer applied in production. To rectify: Seal the affected areas with sealer. B. Water ingress via the fender apron panel outer reinforcement (right-hand vehicle side):
Cause: Water can enter the front footwell between the fender apron panel outer reinforcement and the grommet because of insufficient or intermittent sealer applied in production. To rectify: Seal the affected areas with sealer. C. Water ingress via the pollen filter housing:
Cause: Water can enter the front footwell via an excessively large gap between the pollen filter housing and the cowl panel grille as well as certain body joints. To rectify: Seal the affected areas with sealer. D. Water ingress via the liftgate/rear door weatherstrips:
Cause: The adjustment of the right-hand door check arm, a hardened blanking plug on the D-pillar, an incomplete seal at the liftgate hinges or an inadequately-installed door weatherstrip can result in water ingress in the rear section of the loadspace. To rectify: Adjust the door stop, install a new cover plug, correct the position of the rubber seal on the rear door. E. Water ingress via the C-pillar in the area of the sliding door:
Cause: Water can enter the interior between individual body parts of the sliding door guide because of insufficient or intermittent sealer applied in production. To rectify: Seal the body parts of the sliding door guide from the interior using additional sealer. F. Water ingress via the roof rack blanking plugs and the ventilation flaps:
Cause: Water can enter the interior via a deformed blanking plug bore, missing or damaged roof rack blanking plug seals or via the ventilation flaps in the rear section of the vehicle roof. To rectify: Remove the blanking plugs and install new roof rack blanking plug seals. Install new ventilation flaps. G. Water ingress via the sliding door:
Cause: Water can enter the interior via a damaged watershield and an inadequate seal at the upper sliding door guide. To rectify: Install a new watershield and seal the upper sliding door guide with additional sealer. H. Water ingress via the rear side windows:
Cause: Water can enter the interior via an incorrectly-installed rear quarter window glass weatherstrip. To rectify: Correct the installation position of the rear quarter window glass weatherstrip and seal with additional sealer. I. Water ingress via the rear door central high mounted stoplamp:
Cause: The stoplamp opening on the rear cargo door outer sheet metal is out of tolerances causing insufficient seal area.
3/11/11 Water ingress into the interior; Windnoise from the front door; Upper front door weatherstrip loose or comes adrift on the A-pillar sheet metal
Water ingress into the interior, windnoise from the front door or that the upper front door weatherstrip becomes loose or comes adrift on the A-pillar sheet metal, the probable cause is poor installation of the weatherstrip in conjunction with minor adhesion of the adhesive strip.
To rectify this concern, the affected upper front door weatherstrip should be renewed. To improve the adhesion primer should be applied to the installation area.
3/9/05 Water entering into the interior; Noises coming from the area of the load space roof opening panel
There have been various concerns where water enters into the interior and over noises coming from the area of the load space roof opening panel:
1. Water entering from the D-pillar upper sheet metal connection points into the interior
Cause: Gap between flanges because of insufficient sealant applied in production. To rectify: Seal the affected areas with clinched flange sealer. 2. Water entering into the interior between the weatherstrips of the load space roof opening panel and the body
Cause: Water can enter the interior because the seal gap is too large. To rectify: Loosen the tail roof opening panel striker screws and move the load space roof opening panel striker upwards to decrease seal gap. 3. Water entering from the sheet metal connection points of the drain channel into the interior.
Cause: Insufficient sealant applied in production. To rectify: Seal the affected areas with clinched flange sealer. 4. Water entering via the weatherstrip on the rear doors into the interior
Cause: Water entering the rear part of the loading space may be caused by an incorrectly installed weatherstrip on one or both of the rear doors. To rectify: Realign the flange angels. 5. Water entering into the interior from the load space roof opening panel watherstrip
Cause: Inadequate sealing of weatherstrip. To rectify: Apply clinched flange sealer to the inside of the weatherstrip. 6. Water entering into the interior from the load space roof opening panel weatherstrip
Cause: Inadequate sealing of weatherstrip. To rectify: Apply clinched flange sealer to the end of the weatherstrip carrier. 7. Water entering the rear part of the loading space from under the flap of the weatherstrip carrier
Cause: Inadequate sealing of weatherstrip. To rectify: Apply clinched flange sealer to the flap. 8. Noises from the load space roof opening panel (only vehicles build up to 05.10.2004 (build code 4Y))
Cause: Load space roof opening panel hinges not robust enough. To rectify: Install new load space roof opening panel hinges. Vehicles built from 06.10.2004 (build code 4Y) onwards have already the new hinges installed.
metalworker0 wrote:Watch this video "not connect"..seems that when the pipe gets blocked internally it fills the whole chamber up ..and it starts leaking elsewhere .
https://www.youtube.com/watch?v=oVR5um8Dzj0
