Legalities of alloys / tyres on the Connect :)
Re: Legalities of alloys / tyres on the Connect :)
Postby mrtn » Sat Mar 28, 2015 9:48 pm
Never had any load rating problems at the regular MOT place I go to. Last year I went to some other place, they made a big deal out of the 93-rated snow tyres, instead of the 95 listed in the registration. Started bitching about them immediately.
1.6 Ecoboost A/T LWB '16
mrtn
Postby whatfriends » Tue Aug 04, 2015 10:16 am
Hello there folks.
Was a member of the smiley face gang, but that van went to the big car park in the sky yesterday.
Bought a second hand 2003 connect lx tdci T230 LWB high top yesterday, so now I'm in the transit connect gang.
It came with some alloys on it, and after looking at this thread and doing a bunch of research on my tyres, I know that the tires are good for the load (rated at 105R - 925kg and 106mph).
Questions are....
How do I find out the load rating on an alloy wheel? I believe its a ford mondeo set.
How do I find out if the stud bolts are for alloys or steel wheels, as the book says danger, do not use steel wheel bolts.
Image of van and wheels below in case anyone recognises them. Current size is 205/65 R16. According to sat nav, speedo is dead on accurate.
https://ssli.ebayimg.com/00/s/NjAwWDc5OQ==/z/y0wAAOSwjVVVrmyR/$_86.JPG
whatfriends
Postby g-man » Tue Aug 04, 2015 8:45 pm
they are mk3 mondys........normal ford ally nuts off ebay will fit or go to a dealer........load rating is normally stamped on the inside of the rim :wink:
g-man
Postby whatfriends » Wed Aug 05, 2015 8:26 am
When you on the inside of the rim, do you mean under the tire, or on the reverse so I'd need to take a wheel off to find it?
whatfriends
Postby g-man » Wed Aug 05, 2015 9:08 am
inside face
g-man
Postby whatfriends » Fri Aug 07, 2015 9:45 am
Nice one. I'll check it out. Much appreciate.
whatfriends
Postby LostinTransit » Wed Oct 21, 2015 11:40 pm
Update:
We've found a set of wheel & tires to match.. The tires I've always wanted, but I'm still unsure about the wheels.. Sure they look rugged and all.. and have been proven to actually be rugged.. I'm just unsure of the center bore/wheel ring & the offset. Both aren't that high but still it could be an issue down the road.
One reason I'm posting here is because over these last 6 months.. I found out that those of you who live in Europe got it easy dealing with finding wheels. Proof of this came when I found 6 wheels via fordpartsuk.. the issue was they aren't DOT approved which is one things wheels need to be here in the states. otherwise I would have order wheels from UK.
Never the less we found some and await their delivery.. What wheels & tires did we get for this van?.. While I was swinging from overlander to stance van and back to overlander.. I realized that we're never going to be happy but I didn't want to buy any wheels or tires on impulse.. Picky.. yeah probably.
I think I'm doing these wheels and tires because several TC owners in the states seem to have a fear of doing anything to the van.. so I figured I'd take the lead and grab a wheel and tire that was different and not so "main stream". No we didn't do the Yokohama Geolanders, but we had a waiting list, poised to see this. I've been sending my finding to Wheel-size.com just to help them out and so they had the correct data for other who might be going though the same process we did.
Also & lastly, one reason we've selected these wheels and tires is because of our trip to Arkansas last week.. we found a road out there that really inspired me to think outside the box. Oh the reason we went to AR?.. well seem the storm that was pounding the east coast turn us toward sunny weather.. and where was the sunny shine?.. We had to drive all the way to AR, just for the fun of it.
Looking forward to sharing our wheel/tire finding very soon.
LostinTransit
Postby robfe550 » Wed Oct 28, 2015 5:36 pm
So if you have an L200 SWB with 18's on you have nothing to worry about?
robfe550
Postby LostinTransit » Wed Nov 04, 2015 1:05 am
Image: 16x7 Sparco "Terra" wheels w/ Maxxis Victra 215/55R16 Tires on our 015 Transit Connect
According to the dealership and checking the wheels myself, No wheel weights were added because each time the spun the wheel it cam up balanced.
LostinTransit
Postby jumbo camper » Fri Dec 18, 2015 12:11 am
Any ideas if im ok to run 195/70R15C tyres all round on my LWB transit connect? van currently has 195/65R15 on it at the mo. but ive aquired a set of 5 michelins for a good price? thanks
jumbo camper
Postby T i m » Mon Dec 28, 2015 2:46 pm
highroof wrote:Don't know if anyone else has had this suggested to them, but in a dispute with the dealer supplying my recently purchased used van, I argued that it shouldn't have 91T rated tyres on it with it being a LWB. They replaced the tyres after some to-ing and fro-ing, but countered with paperwork to show that the Connect is a Class 4 vehicle, and only Classes 5 and 7 are required to have correctly rated load index tyres for MOT purposes. I asked another MOT place to confirm this and it appears to be correct.
Yup, that seems to be the case.
So, in short, you can legally have 91T rated tyres on a LWB Connect, and still be within the law..........the grey area being that you could be carrying weight within the limits of the vans capabilities, but not the tyres! And I don't yet know what would happen legally if that were shown to be the case.
Happy motoring!
I think (and has been mentioned elsewhere) it is the drivers responsibility to ensure the tyres are not overloaded, whatever load rating they are (also indirectly in the case of those vehicles where the right load rating is sipulated of course). So, if they have a sufficiently high load rating to support the vehicle when empty then as long as it remains empty then that should be fine (legally).
However, ITRW, I think most people would like the oppertunity to carry up to the maximum permitted capacity of the vehicle (safely / legally) and in that case they would fit tyres with a suitable load rating to accomodate that.
I'm adding my 3dth to this thread now because we find ourselves in the same position with the new_to_us T220, LWB Connect. It came with some fairly new 91T rated tyres on the front and older 95T's on the rear. Now, I've not looked into it closely but I'm guessing it's possible, depending what sort of load you carry and where you place it ... to overload the front tyres whist still being within the load capacity of the vehicle. e.g. a 800kg (or whatever the max load is) lead block up against the bulkhead would probably overload the front tyres whereas the same block over the back axle probably wouldn't.
I think daughter is happy to buy 5 new 95T's (it's her Connect <g>) and then it won't be an issue if she has to move a wheel from front to back or carry a full load etc. ;-)
Cheers, T i m
T i m
Postby Penns111 » Mon Feb 08, 2016 2:18 pm
Hi guys, I have a 65 plate LWB L2 T240 85kw transit connect. This van comes with alloys as standard and tyres that are extra load, max load 710kg 16/205/60R 96H. I would like to put on 18 alloys and have found some with the right 5 x108 bolt pattern with the right bore size of 63.4 with an offset of 40 which is within the range of 35 to 50 and are weight rated 1600kg per alloy. Am I right in saying that this alloy is perfect for this van?
The tyre I have looked at is 215/45ZR/18W 93 weight rated. Can someone advise me on the weight rating for my 65 plate T240 please. Current factory fitted tyre has max load 710kg 96H as listed above.
Penns111
Postby LostinTransit » Wed Feb 24, 2016 6:36 pm
It is good to see that the TC wheel & tire topic is still active.. I'm here today to let others know that there is hope on the horizon for 2014- current TC owners to install larger wheels on their van. I've been in contact with another TC owner here in the states that has just done this to his van:
What you're looking at is this 2015 TC has 18x9 ROTIFORM VCE Monoblocks with 205/40/18 tires.. This may not be so important to those viewing.. what is important to me and many others like me,, is the suspension he used to lower (or raise) the van. This is one smart kid, he cross referenced a few parts and found a manufacture who made a coil over system which he installed on the van.
The issue is here.. is that the manufacture had no clue that this kid simply added this coilover to his van. Even the shop he purchased this coilover system from had no clue what this kid was doing.. Lucky for us, this system can be raise or lowered.. (static, not bagged) and for all those who want to actually raise their TC's.. we''l keep you posted just to see if the manufacture changes their view on this coliover system and to include it for Ford Transit Connects.
LostinTransit
Postby LostinTransit » Wed Feb 24, 2016 6:49 pm
Also, I'm here to pass judgment on our wheels and tires.. Although it wasn't what we originally wanted, the setup has grown on us. However, over these last few weeks, I was able to take my mind off the wheel and tire setup and focus on other matters.. but doing so, allowed me to think clearer about our wheel& tire our purchase.
Let me review the wheels first, (Image Above) these are the Sparco 16x7 (measuring 17x8) rally ready terra wheels.. We love the spoke design which allows for a better air flow when cooling the brakes. $99.00 US dollar seem to be a great deal, because I believe this color wheel has been discontinued.
Onward to the tires, These are the 215/55/16 Maxxis Victra all season tires which are the closest thing we could have found here in the states that resembles an all weather tire. Even though the tires were 2 1/2 years old, they handle extremely well in all types of road conditions. However there is one issue and I now regret making this mistake.. I was so intent on trying to locate a 17'' wheel that I over looked a tire size.. all this time I was wanting larger wheels with larger tires.. and this couldn't be accomplished.. (within the list I was given)
Turns out that I should have purchased the 16x7 sparco wheels with 225/55/16 maxxis tires.. this would have offer us the slight boost I had originally wanted in the first place. So now we'll have to wait 55K miles to get the correct size tires.
LostinTransit
Postby LostinTransit » Wed Mar 09, 2016 9:17 pm
LostInTransit wrote:It is good to see that the TC wheel & tire topic is still active.. I'm here today to let others know that there is hope on the horizon for 2014- current TC owners to install larger wheels on their van. I've been in contact with another TC owner here in the states that has just done this to his van:
Just got an email from the product developer Richard Kong via Megan Racing;
Hello,
We currently do not have a coil over kit for this car, nor do we intend to manufacture one at this time. We have contacted the owner and he confirmed what we already suspected. He used one of our Ford kits to make this setup work. I do not advise that this setup be used on your car, since the rear set up in those images do not actually fit the car.
Thanks,
Richard Kong
Development & Operations Manager
Megan Racing Inc
19481 San Jose Ave
So what just happen?.. the kid didn't even have these coil overs installed correctly, thus offering a false sense of hope for other TC owners who might have wanted to lower or raise their TC's and by the way.. I found out what load rating was on those tires he installed.. a mere 87.. which is way below what it should be..
As of right now, their but one company offering coil over lowering kits for older TC's: http://www.hrsprings.com/products/coil-overs/
LostinTransit
