NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby purplebargeken » Thu Feb 06, 2014 11:40 pm
I've been reading through the thread and am simply in awe of what you have done.
Some folk do point out that you could have bought this or that and saved yourself some hassle but I guess that part of this was to see if it could be done and to push your own (copious) skill to further limits.
I think what you have done is brilliant and the van looks bloody great. Huge thumbs up to you and thanks for sharing the build.
purplebargeken
Postby paul2012 » Thu Feb 06, 2014 11:48 pm
liteace wrote:Nasty, cheap Chinese tyres, no thanks, is it not best to spend a little more on things like tyres and brakes !
Well thats your opinion :roll: I go by tyre ratings & not price 8)
Did compare a few tyres in my local area for 205/50/17's
Dunlop Sport BluResponse rating was Fuel efficiency B/ Grip A £165 per tyre
Goodyear EFFICIENTGRIP is Fuel efficiency C/ Grip B £102 per tyre
Michelin Pilot Sport 3 rating was Fuel efficiency E/ Grip A £139 per tyre
Kumho KH31 rating is Fuel efficiency E/ Grip B £68 per tyre
Bridgestone Potenza RE002 rating was Fuel efficiency F/ Grip C which is crap for £106 per tyre !
Continental contipremium contact 2 Run flat rating was Fuel efficiency F/ Grip C which is crap for £139 per tyre ! (Transit sportvans had problems with these :!: )
Infinity INF-05 rating was Fuel efficiency F/ Grip E £55 per tyre
liteace wrote:At least Kumho are listed in the tyre test, those Shengtai rapdis, cant even find them
Kumho tyres are manufactured in China & Korea & are OEM for Kia, Mercedes & VW. So I wouldn't say all tyres manufactured in China are nasty :?
Rapid P609 tyres are listed here :arrow: http://www.bigtyres.co.uk/index.php?pag ... &Itemid=19
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Thu Feb 06, 2014 11:59 pm
purplebargeken wrote:I've been reading through the thread and am simply in awe of what you have done.
Thanks :D
It would have been easier to fit 2009 onwards wiring loom, but decided to reconfigure the earlier looms instead.
Basically to see if it could be done or not, as I've never done it before on a connect :mrgreen:
paul2012
Postby liteace » Fri Feb 07, 2014 9:22 am
Yep they might be listed for sale but I though they may have had a tyre test \ reviews somewhere, I checked here:
http://www.blackcircles.com/tyres_uk
Here:
http://www.which.co.uk/cars/driving/car ... re-brands/
and here:
http://www.tyrereviews.co.uk/Tyre/
And could not find anything :?
liteace
Postby paul2012 » Fri Feb 07, 2014 9:32 pm
As requested.
Bonnet switch comes complete with mounting bracket
& it mounted in engine bay on N/S
Bolt holes are already present as outlined below
Bonnet switch could be used for aftermarket alarm systems with ease :wink:
paul2012
Postby paul2012 » Mon Feb 10, 2014 8:41 pm
*** TIP ***
If fitting a 2009 dash in an early connect & have a headlamp switch like mine.
Which has a poistion on it for "parking lamps"
They are very easy to wire up.
Simply add a short section of wire from pin 2 on ignition switch & connect to pin 12 on headlight switch. once done parking lamps will now work. :D
(can also be done on Transit mk7)
paul2012
Postby paul2012 » Wed Feb 12, 2014 10:49 pm
As shown on page 16 of this thread
I only have 1 radiator fan (larger one) which is common on early connects. Compared to later connects that have a smaller one instead.
After checking wiring & relay's, Larger fan is secondary & smaller one is primary. (wiring & both relays are present on my 2007 engine bay loom)
So I have obtained a smaller fan from a 2009 connect.
paul2012
Postby liteace » Thu Feb 13, 2014 9:35 am
Only Connects with aircon have 2 fan's, no aircon the other one wont do anything unless the engine is realy hot, bit of a waste of time fitting the second one unless you planning driving through the sahara desert
liteace
Postby paul2012 » Thu Feb 13, 2014 1:00 pm
liteace wrote:Only Connects with aircon have 2 fan's, no aircon the other one wont do anything unless the engine is realy hot, bit of a waste of time fitting the second one unless you planning driving through the sahara desert
Agreed, unfortunately as my connect has no primary cooling fan (smaller one) fitted - Secondary Fan is for A/C
So when it's required to be on like during hot weather in the summer (if we get any :? ) it's not there.
Hence the reason I'm fitting it. :wink:
paul2012
Postby paul2012 » Fri Feb 14, 2014 12:12 am
Fitted passesnger seat & rest of interior today.
Picking up door handles tomorrow as there've been painted :D
Due to gale force winds, Now I have 22ft of fencing to fix :evil:
paul2012
Postby paul2012 » Sat Feb 15, 2014 10:02 pm
Got new front brake discs & pad today (Transitparts uk)
Hopefully get them fitted other the weekend.
paul2012
Postby paul2012 » Sun Feb 16, 2014 8:34 pm
Fitted new front discs & pads along with the new tyres
Also refitted N/S wheel well liner
Just need to get 2 new tyres for the rear.
paul2012
Postby paul2012 » Tue Feb 18, 2014 10:30 pm
Still looking for a pair of door cards in dark pewter, must be for elec windows.
As you can see my original grey ones don't match the dash :(
Other than door cards, Parts left get to complete project is :-
2 new rear tyres, new pedal rubbers & new heated windscreen.
I have not decided wether to get side skirts of not ?
If any one has doors cards I am looking for, please let me know. My grey ones will be available.
paul2012
Postby Ploen » Wed Feb 19, 2014 10:13 pm
paul2012 wrote:I have not decided wether to get side skirts of not ?
Is there à wat to buy them other then the dealer? They cost à lot from à ford dealer for just
two pieces of plastic........ :?
Just Connecting
Ploen
Postby paul2012 » Fri Feb 21, 2014 7:13 pm
Thery were expense over a year ago, Hopefully price will have fallen due to the arrival of the New Transit connect.
I have not decided yet wether to get them or not.
paul2012
