NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Sat Nov 29, 2014 6:07 pm
loot34 wrote:Paul, where is project 1?
Project No 1 is here :arrow: viewtopic.php?f=54&t=116284&hilit :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby loot » Sat Nov 29, 2014 6:40 pm
Ah 8)
Ids map here
loot
Postby Cresser » Thu Dec 11, 2014 6:45 pm
paul2012 wrote:***UPDATE***
Thankyou to members interested in this connect.
On a first come first served basis.
1 member on here who contacted me a few weeks ago regarding sale.
Has paid a deposit today to secure sale. :D
Good to see that you finished the project. Very tidy. Have to ask..... how much did you sale it for?
Transit Connect LWB TDdi 75HP 2003. Focus air box mod + EGR blanked.
Cresser
Postby paul2012 » Thu Dec 11, 2014 6:59 pm
Thanks 8)
It sold for £3800 :D
paul2012
Postby Dicey t » Thu Dec 11, 2014 9:39 pm
Sure did and I have spent 3K on it already :wink:
When yi get a min Paul could do with diagram for DRL's 8)
CheeRS
Dicey t
Postby paul2012 » Fri Dec 12, 2014 10:09 pm
Dicey t wrote:Sure did and I have spent 3K on it already :wink:
CheeRS
Most of that would be on new paint job..
Wiring diagrams for factory DRL's - uses front side/position lights & tail lights.
I can supply wiring details for after market DRL's if required. :wink:
paul2012
Postby Dicey t » Fri Dec 12, 2014 10:32 pm
Yip total new paint job and full body kit :mrgreen:
No got a clue with the wiring diagram Paul :?: is it just like something I plug in ?
CheeRS
Dicey t
Postby jasonescortcozzie » Sat Dec 13, 2014 4:13 am
Pictures Dicey. T?
jasonescortcozzie
Postby Dicey t » Sat Dec 13, 2014 9:23 am
Goes to paint shop today should take about a week 8)
Will post when it done ok
CheeRS
Dicey t
Postby Cresser » Sun Dec 14, 2014 9:04 pm
I look forward to seeing it. looks like Paul has done a proper job there and it is good to know that it has gone to a good home.
Cresser
Postby Hotwheels » Thu Dec 25, 2014 1:10 am
paul2012 wrote:New dash is fully wired up, just require to get speedo working.
Next job is to fit ABS brakes, As this is what generates the vehicle speed signal for tne instrument cluster. (Ford decided to lose the VSS sensor on the gearbox from 2006 onwards)
I already have a spare rear disc brake ABS axle & grabbed this lot at a bargain price of £60 :D
very easy to fit :wink:
Do you have to fit the extra parts for the ABS when you change the dashboard as I am looking into this in the new year cheers.
Hotwheels
Postby paul2012 » Thu Dec 25, 2014 1:24 am
Hotwheels wrote:
paul2012 wrote:Image
Only parts I used in that pick where front hubs & mater cylinder- rest of parts came from a 2010/2012 connect.
I fitted ABS/ESP as it was tied into engine management & supplied vehicle speed for the 2010 instrument cluster.
You don't have to do the same.
When I fitted a 2010 dash to DHOCARL's Connect. I modified dash to fit his original instrument cluster
& modify wiring for air rec switch, hazard & heated screen/mirror switches :wink:
See here :arrow: viewtopic.php?f=54&t=92502&p=1277102#p1277102
paul2012
Postby Hotwheels » Thu Dec 25, 2014 1:37 am
Only parts I used in that pick where front hubs & mater cylinder- rest of parts came from a 2010 connect.
Hi Paul I still have the old set-up of drums on the rear but the van has now been lowered and has focus RS suspension on the front I don't want to go over the top but was just considering fitting the dash in the new year. Would it just be a straight swap without altering the wiring et'c or would you recommend getting an Auto Electrician to change things over.
Hotwheels
Postby paul2012 » Tue Dec 30, 2014 7:21 pm
Dicey t wrote:Yip total new paint job and full body kit :mrgreen:
CheeRS
Are you going to fit aftermarket DRL's or require factory option - where side/position lights that are used as DRL's :?:
Reason I ask as wiring Is different for both options.
paul2012
Postby paul2012 » Tue Dec 30, 2014 7:23 pm
Hotwheels wrote:Hi Paul I still have the old set-up of drums on the rear but the van has now been lowered and has focus RS suspension on the front I don't want to go over the top but was just considering fitting the dash in the new year. Would it just be a straight swap without altering the wiring et'c or would you recommend getting an Auto Electrician to change things over.
Sent you a PM :wink:
paul2012
