What did you do to your connect today?
Re: What did you do to your connect today?
Postby Mylee » Thu May 31, 2012 10:25 pm
Connect-rick wrote:paul2012, liking the front bumper mate was it a straight fit? been looking on fleabay at them but wasnt sure if they were interchangeable? dont like the bumper on mine think they look a bit crappy!
Straight fit, but you need arches and front splitter as well.
Mylee
Postby dieselboy1978 » Thu May 31, 2012 10:42 pm
Why do you need new ones? Are they different arches?
Couldnt the old ones be used just out of interest
Bank account emptied by
DELPHI
dieselboy1978
Postby Mylee » Thu May 31, 2012 10:46 pm
dieselboy1978 wrote:Why do you need new ones? Are they different arches?
They are different.
Mylee
Postby dieselboy1978 » Thu May 31, 2012 10:50 pm
The bumper I want to fit is like the one you have on yours but it has fog lights in correct and I don't have the facility for fog lights in my current van (wiring etc)
Any ideas of part numbers for front bumber or a reg that the bumper comes from so I can source front bumber, arches and splitter for?
Sorry for being a pain
Peter
DELPHI
dieselboy1978
Postby Mylee » Thu May 31, 2012 10:55 pm
Best place to look is the Bay, but go for genuine. Sorry don't know the part nos. Doesn't matter about the fog lights, the bumper will fit, loads of us have done this mod on here.
I Use my fog lights, fitted with LED's as DRL. On with ingnition, off with side lights via a DRL relay. Not legal, but never had an issue at MOT time or with the rozzers
Mylee
Postby dieselboy1978 » Thu May 31, 2012 10:59 pm
Ok thanks mate.
Will have to source bumper etc first then get all the wiring sorted for fog lights etc.
Peter
DELPHI
dieselboy1978
Postby Mylee » Thu May 31, 2012 11:06 pm
I have an original fog light switch (the one built into the headlight switch if you want it) £10
Mylee
Postby dieselboy1978 » Thu May 31, 2012 11:34 pm
Very interested
DELPHI
dieselboy1978
Postby paul2012 » Fri Jun 01, 2012 5:20 am
wilkyd53 wrote:
paul2012 wrote:Got a set of 4 brand new tyres - 225/40/18 92 from ebay for £200
Now got my wheels fitted although I still have to refurb the rims - there no tyres rubbing at all, not even when steering is on a full lock ! :D :D
That shouldn't come as a surprise as these are the same circumference and only 15mm wider than the original tyres.... unless I've missed some other mod? :P
The original wheels / tyres where 195/65/15 91 & the new one are alot wider
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Fri Jun 01, 2012 5:22 am
Hi yes front bumper was a straight fit, but you will need the later wheel arch trims as well. As they aslo connect to the front bumper
paul2012
Postby paul2012 » Fri Jun 01, 2012 5:32 am
Mylee wrote:I have an original fog light switch (the one built into the headlight switch if you want it) £10
There are 2 different typres of connect headlamp switches
This Headlamp switch below only turn the rear foglights on
This one below turns the rear & front foglights on
Which switch do you have available ?
paul2012
Postby Telemark » Fri Jun 01, 2012 10:19 am
I gave it "new" wheels, from a Mondeo, 235/45-17 97W Goodyear Excellence.
2008 Connect T220 LX tdci 75ps
Telemark
Postby Lefty64 » Fri Jun 01, 2012 5:16 pm
I know, but the new setup is still the same size as the old so won't foul the arches. They're only 15mm wider on each side which is nothing.
The 235/45/R17 (above) are larger and wider, but there's still plenty of clearance even with these.
2007 T230LX LWB (110PS) with aircon.
Vans are designed for people with imagination. Cars are so limiting ... what can you do with them?
Lefty64
Postby paul2012 » Fri Jun 01, 2012 9:19 pm
I did not mean tyres rubbing against the arches as there's plenty of room there. I mean the tyres are not rubbing against the inner wing splash guards that are fitted behind the front suspension legs ! when steering is on full lock. I have less then 1cm clearance between the back of rim and the suspension leg.
You can't even get your finger between the rim & Suspension leg !!
Also 18" Rims are far bigger & wider than 17" rims
Yes the new tyres are the same circumference / Rolling Radius, so the speedometer reading remains the same. But they are low profile & 30mm wider than the old 195 65 15 tyres
paul2012
Postby paul2012 » Fri Jun 01, 2012 10:33 pm
I gree that the 235/45/17 tyres are bigger but they are on smaller alloy wheels !
Now if I had fiited 235/45/18 tryes to my 18" ST alloys wheels, I would not be able to fit them on my van, Due to the tyres would be rubbing against the front suspension legs & the inner wing splash guards, Also the tyre circumference / Rolling Radius will be 10cm bigger !!
The speedometer readout would also be inaccurate. (basically you would be traveling faster than what the speedo says)
paul2012
