paul2012 wrote:After a few PM's Here is the resquested info on how to enable auto wipe/headlights with alarm on 2009 onwards connects
Parts required
Rain/ light sensor with plug & lengh of wiring - part no - 3S7T-17D547-AB
Rain/light sensor bracket/covers part no's F1488557, F1710216 & F1687666
headlamp switch with auto lights - part no 4M5T-13A024-DA
GEM module (MUST have CTM CL RKE AS on label) Part no 9T1T-15K600-ED
Antiptheft horn part no 2T1T-13832-AD
Bonnet switch part no F3553259
Rain sensor wiring details
Pin 1 on sensor connect to Pin 8 on headlight switch
Pin 2 on sensor connect to GND
Pin 3 on sensor connect to GEM connector BL pin 22
Autolights wiring details.
Pin 4 on headlight switch connect to GEM connector IPR pin 21
Alarm wiring details
Anti-theft horn connect to GEM connector IPL pin 1
Pin 1 on Bonnet switch (hood ajar) connect to GEM connector BL pin 23
Pin 2 on bonnet switch connect to GND
GEM programming instructions Ford IDS required.
Before connecting VCM/VCMII to vehicle.
Unplug GEM module.
disconnect toughbook/laptop from internet & then run IDS (by disconnecting from internet, IDS can't download vehicle's "As Built Data")
Once IDS has communicated with vehicle. Select Module programming & then Programmable module installation (PMI)
Select GEM, IDS will attempt to download "as built data" it will then give option to manually configure GEM module.
Select manual configuration & enter the following codes when instructed too. ( there are 3 programming codes to enter in - 1 at a time, shown in yellow box below)
Once done IDS with ask for module to be installed. At this point plug GEM module back in & follow instructions on IDS to complete process.
Now you have automatic wipers & headlights with Alarm
