What did you do to your connect today?
Re: What did you do to your connect today?
Postby westers » Tue Jul 10, 2012 8:26 pm
mike-dyson wrote:http://www.youtube.com/watch?v=LuDN2bCIyus
i don't know if anyone is a fan of ken block but his new video came out yesterday if anyone fancys a watch.
saw it yesterday mate! hes an incredible show driver! ... not such a great rally driver :roll: , but an epic show-off :P
i might fit a hand brake like his to my van 8) haha :lol:
WESTERS T220 LX connect
westers
Postby Hotwheels » Wed Jul 11, 2012 12:18 am
valetech wrote:
Drizz wrote:Well today i collected some of my facelift parts:
Just need rear arches, and rear end caps.
When colour coding the fog surrounds, have you that have done it, melted them off and reattached, or masked and painted?
Also i need the little bumper bits.
As far as the rear bumper goes, is there a little grommet for the towing eye hole? Also do the rear parking sensors have washers/seats that go between them and the bumper itself?
Thanks in advance....
Yes you get a better job by removing the fog surrounds
Factory parking sensors are on spacers so them don't point down.
Yes a round cap for the towing eye.
If you need someone to do the colourcoding :wink: only in bishops Stortford
How much did it cost for the parts and were can i get them from also any instructions for fitting as i have a 2002 connect van SWB model no side door cheers Mate.
Hotwheels
Postby Drizz » Wed Jul 11, 2012 7:02 am
I paid £333 for the primered version of the front bumper, front arches and rear bumper, the £35 for the rear end caps and top trim and the rear arches I'm yet to order are £22 each. Then the parking sensor collars and all three towing eye caps were £25 from fords. Not painted yet so fitting I've not a clue on..
Drizz
Postby paul2012 » Wed Jul 11, 2012 5:53 pm
Drizz wrote:I paid £333 for the primered version of the front bumper, front arches and rear bumper, the £35 for the rear end caps and top trim and the rear arches I'm yet to order are £22 each. Then the parking sensor collars and all three towing eye caps were £25 from fords. Not painted yet so fitting I've not a clue on..
HE HE :lol: :lol:
I reconise the Label on the front arch trim packaging ! (I had the same label on mine)
There are supplied by Imperial Crash Repair Parts. Price list can be found here :-
http://www.crashrepairparts.com/parts/m ... r?_ts=1448
BUT they do not supply the rear arch trims or the rubber spoiler for the bottom of the front bumper ! (2 parts)
I got my rubber spoiler for the front bumper from http://www.hamtunespares.co.uk/ £22 for both parts
I did not go for the primed bumper, I got the unprimed one (cheaper) & had it proffessionally painted & baked at my brothers workplace for £20 (he works at Bennets Accident & Rapair Centre - Insurance Approved). 8) 8)
Ps if you van colour is white - specifically DIAMOND WHITE , Please Note there are 2 different colour versions. If you get the wrong one, you will notice the slight difference in colour match !
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Drizz » Wed Jul 11, 2012 6:48 pm
I dropped the parts to the painters today. They mentioned the various shades so they will do what they need to to match it
Drizz
Postby Drizz » Thu Jul 12, 2012 8:12 pm
Started as this:
During:
And after:
I know its a common mod but makes a big difference. Ill be colour coding the writing too.
Done some more mods to the bulkhead, i.e. making a window, cutting out port holes so they fire in the cab, and holes for the speakers ill get round to fitting!
And temporarily back in. Tool box moved to side door for easy access, and both sub boxes mounted. The Ports fire into the cab and its not hugely loud, but enough! I am thinking of cutting holes above the boxes the same size as the box face, and making a curved funnel so the subs also fire in the cab. Not too sure if itll work or not so ill be asking on the audio forums.
Drizz
Postby westers » Fri Jul 13, 2012 7:23 am
Just bought some focus st-2 blue cloth recaro's for £100!! Will post pics tomoro when I pick them up :mrgreen: :mrgreen: :mrgreen:
westers
Postby paul2012 » Fri Jul 13, 2012 3:06 pm
Still adding more connect mk2 parts to my van !
Most of you will find that the Early mk1 connects had the reverse gear locking ring located just below the gear knob (had to be lifted before selecting reverse)
Due to this the Mk2 gear knob would not fit, here how to do a very easy mod ! - Takes only 3 minutes to complete from start to finish
Gearshift assembly in clear view
Disconnect the upper gear control cable (push the centre button & pull away from ball mounting), Nexted removed the single screw, Remove all parts shown in photo below (they all slide off the gearshift)
These parts in photo are no longer required
Do not forget to re-tighten the screw !
Reconnect the upper gear control cable, Now should like this
Finally replace upper cover before screwing the replacement gear knob on - job done
Yes you can see the colour difference between the new upper gearshift cover & the trim between the seats, this was the original colour of my dash. door cards etc. The new upper cover is the same colour of my mk2 dash & door cards & also same colour of my leather seats :D :D
This is what my van interior used to look like
I will be replacing the gear knob with one from a fiesta or focus (a leather one with silver / aluminium insert). Will be replacing the centre trim between the seats with one from mk2 connect also
This what is looks like now with connect mk2 2008 dash, door cards etc fitted :D :D
The leather passenger seat is not fitted yet just waiting for parts to arrive (see my other thread reguarding seat fitting)
paul2012
Postby Mylee » Fri Jul 13, 2012 4:10 pm
Ever thought it might be easier to just buy a Mk2 connect? :?
Mylee
Postby paul2012 » Fri Jul 13, 2012 5:18 pm
Mylee wrote:Ever thought it might be easier to just buy a Mk2 connect? :?
Yes it would be easier, :lol: :lol: :lol:
BUt this van is alot cheaper than price for a mk2 connect. I did not plan on changing the dash, but when I got the elec windows & mirror kit is came with everything. It did not look right with a multi- coloured interior !
It's a project 8) 8)
& I have done quite a few other vans in the past.
For example this 1997 Merc Vito 108D, which I customised & fitted turbo to it ! sold few months ago for £3000
paul2012
Postby Drizz » Fri Jul 13, 2012 5:55 pm
Where did the vito body kit come from? I've got a vito too so looking at ideas to tidy it up
Drizz
Postby inzor » Fri Jul 13, 2012 7:30 pm
used the dvla site to look up the MOT history as my van only came with the most recent certificate, no service history either, drives well though.
also ordered new wiper blades, went for aero blades. and currently tring to buy a set of wiper arms as one of mine has fell apart.
inzor
Postby dieselboy1978 » Fri Jul 13, 2012 10:00 pm
Fiited a de-cat pipe and a stainless exhaust system.
De-cat i got from Mylee and exhaust from Kent Disco.
Exhaust needed some modifications to make it fit as was too short and now knocks but that will be fesolved on Monday once up on a ramp. Sounds sweet though.
Bank account emptied by
DELPHI
dieselboy1978
Postby Drizz » Fri Jul 13, 2012 10:05 pm
Any obvious gain?
Drizz
Postby GKandR4CH » Fri Jul 13, 2012 10:05 pm
Pleased I didn't buy it then.
Read the forum rules
GKandR4CH
