NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby millertime_1985 » Fri Jun 14, 2013 8:12 pm
paul2012 wrote:
millertime_1985 wrote:
by the end of your project, how much of your van will remain the same as when it was shipped out of turkey...
and.. how much do you reckon you will have Saved, over just buying an "09" model TC?
Not alot is original for a 9 year old connect apart from the shell everthing else has been replaced at some point.
With the cost of van & parts for conversion, estimated cost to date is around £2000
Alot cheaper than a good used low mileage 2009 onwards basic model :mrgreen:
:o ... I was expecting a much higher number. especially considering that your van doesn't look like a garage contract job, especially amazing since you've basically done it all yourself, and its almost totally indistinguishable from a production "09" model
Its Not a Van..... Its a Transit
millertime_1985
Postby paul2012 » Fri Jun 14, 2013 8:47 pm
:D 8)
The only thing I didn't do was the paint work (front bumper painted & bonnet repainted) As they were done at my brothers workplace :wink:
I have yet to get the rear bumber painted up, So I now have the joy of removing it :lol:
Hopefully it should be fairly easy, it looks relatively new with no corrosion on it.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby millertime_1985 » Fri Jun 14, 2013 9:31 pm
:D 8)
well I have 2x spare nuts if you want them... like I said in the other thread I bought 4x anticipating problems... but if you can use them, your welcome to them FoC
I was genuinely shocked at the amount of rust/corrosion on the inside and top edge of my old bumper... so id say your best to plan for the worst
millertime_1985
Postby paul2012 » Sat Jun 15, 2013 7:40 pm
After searching everywhere for new clips for the forward section of centre floor console.
In the end, I got them from Ford at a cost of £3.50 each :shock:
Ford part No F4493651
These are used to clip lower sides of console to the mounting brackets :wink:
paul2012
Postby millertime_1985 » Sun Jun 16, 2013 11:03 am
paul2012 wrote:After searching everywhere for new clips for the forward section of centre floor console.
those look like the same clips used to hold the bumper corner caps on... but £3.50 each is taking the p*ss
millertime_1985
Postby g-man » Sun Jun 16, 2013 11:37 am
star clips for rear cap ends.....these look same as w/arch clips
g-man
Postby Honey monster » Sun Jun 16, 2013 12:07 pm
Check out. Wurth website, they sell loads of different clips,fasteners. Really good quality.
Honey monster
Postby millertime_1985 » Sun Jun 16, 2013 12:55 pm
g-man wrote:star clips for rear cap ends.....these look same as w/arch clips
ah, but are they the same thing...
cos when I compared the star clip/cirle with teeth clips thingy I bought for my bumper corner caps... and the ones holding on the rear wheel arch, they looked identical
millertime_1985
Postby paul2012 » Sun Jun 16, 2013 2:47 pm
Thats what I thought,
These new ones are smaller & have a different part number :?
paul2012
Postby paul2012 » Sun Jun 16, 2013 6:08 pm
Fitted ESP Yaw Rate sensor with mounting bracket today 8)
This is where they are located, & mounted at the base for gearshift assembly.
Yes I also have a 2012 RCM (Airbag module) fitted, unplugged as I am still working on wiring. I don't want to accidently deploy the airbags :oops:
New clips fitted to sides of centre floor console forward section.
paul2012
Postby paul2012 » Wed Jun 19, 2013 9:03 pm
Fitted standard stereo head unit today
All working perfectly & communicating with Instrument cluster as it should do :D
paul2012
Postby millertime_1985 » Thu Jun 20, 2013 3:24 pm
just out of interest... have you spoken to your insurer yet?
I mean, it is one major facelift.. and you know what insurers are like...they will use any excuse to avoid paying out...
millertime_1985
Postby paul2012 » Thu Jun 20, 2013 11:50 pm
millertime_1985 wrote:just out of interest... have you spoken to your insurer yet?
No not yet, as its still off the road (tax & mot expired).
I may end up re-registering it with DVLA, as it's radically altered :lol:
will have to check with DLVA on that one.
But it will keep its original reg no :wink:
paul2012
Postby ginsters » Fri Jun 21, 2013 8:29 am
just read all this thread Paul your nuts!i don't mean that in a negative or nasty way but you might want to phone the mind helpline!
the red ones go faster...
53 plate 75ps lwb
vantunner remap and all the other jazz
unfortunately the doors aint as great as the caddy
north wales where the the men are men and the sheep are scared!
ginsters
Postby paul2012 » Fri Jun 21, 2013 7:07 pm
ginsters wrote:just read all this thread Paul your nuts!i don't mean that in a negative or nasty way but you might want to phone the mind helpline!
Possibly abit eccentric :lol: :lol: :lol:
Probably gone overboard on this project. But then, do like a good challenge :wink:
Currently deciding on what to do with engine ?
Thinking of changing it for the 1.8 TDCI 125ps engine (QYBA) from a Mondeo mk4 along with the 6sp gearbox 8)
Which should return better MPG & no need to worry on power to weight ratio.
Mondeo mk4's gross weight is heavier than my T200 connect :wink:
paul2012
