Honey monster wrote:http://www.ebay.co.uk/itm/SWIVEL-AIR-VENT-CAR-KIT-MOUNT-HOLDER-FOR-APPLE-IPAD-2-/170667303845?pt=UK_iPad_Tablet_Accessories&hash=item27bc9063a5#ht_1877wt_1270
http://www.ebay.co.uk/itm/2-Tubes-Super ... 706wt_1270
Job done
dieselboy1978 wrote:mike-dyson wrote:Added passengers seat Mk3 Mondeo St220 Recaro and made a nice sticker for the plate seat bolted too.
what is it you have done here? is it a steal plate with the seat welded to it and and bolted into the van?
I'm looking at getting some better seats for mine and i think this could be the solution to fitting some.
No welding mate.
Taken standard seats out, Got some metal plate, about 1/4 inch thick, and picked up the existing bolt holes in chassis.
Then worked out where the seat sits best on the plates and drilled and tapped thread into plate.
Bolted seat onto plate. If need to put original seats back in then plates just come out and seats bolts back onto floor plan.
Used 12.9 or 14.9 high tensile bolts for bolting plates and seats in. No worries about bolts snapping or ripping from threads.
Then I just powder coated the plates to make the finish much better and put a green sticker saying CONNECT to finish it off.
C8XY wrote:Installed some reverse parking sensors. Nice and easy
westers wrote:C8XY wrote:Installed some reverse parking sensors. Nice and easy
im tempted with reverse sensorsjust to make the van look more posh
SWtechnologies wrote:so i got my rear disc conversion fitted today... still need to fit h/brake cable as motor factors i use couldn't get me one till tomorrow!
thanks to modyourtransit.com for helping to empty my bank account!!!![]()
rennie wrote:One point worth a mention is the sensor's for the connect.The Xvision one's I originally installed were flat one's and beeped far too often - due the downward angle after fitting to the bumper.
Do your's work OK as they look a flat too?
Corrected after by fitting Xvision angled one's which work perfect.
