What did you do to your connect today?
Re: What did you do to your connect today?
Postby connect_4 » Fri Jul 27, 2012 8:29 am
Dub-77 wrote:Andy you explain it very well thanks (again) but I'm having my plated made and wanted th holes all drilled and ready to go straight on so I as looking for a defo measurement without fitting and unbolting and re drilling etc. so was gonna get centre hole drilled 15 mm fwd ??
It all depends on how low your van gets when you lower it, why not get the centre hole elongated so you can adjust the position of the axle whilst on the van if needed. Just make sure you adjust the same each side of the van.... :D
once the leaf springs are tightened up with the leaf spring U clamps then the axle wont move on the plate.
just an idea.
cheers
Andy
connect_4
Postby connect_4 » Fri Jul 27, 2012 8:30 am
valetech wrote:i agree with some of it,BUT you do not need to move the axle back for it to sit in the middle
what do you need to do then ?
if there's a simpler way then share it, saves the fella doing more work than needed.
cheers
connect_4
Postby Dub-77 » Fri Jul 27, 2012 9:23 am
Yes please tell me... :wink:
Dub-77
Postby GKandR4CH » Fri Jul 27, 2012 12:26 pm
The answer is:-
http://www.modyourtransit.com
0808 225 85 85
Read the forum rules
GKandR4CH
Postby Graham Taylor » Fri Jul 27, 2012 12:58 pm
To be revealed after the break?
Graham Taylor
Postby connect_4 » Fri Jul 27, 2012 1:00 pm
GKandR4CH wrote:The answer is:-
0808 225 85 85
not everyone wants to line someone elses pockets...
why don't you want to share info ?
the way i told the OP is free, why would he want to pay someone else to do it, stop being so secretive and expect members to pay for it.
this forum is surely to help each other and NOT an avenue to squeeze money out of members.
I like to share the stuff i do to hopefully enable others to do the work themselves, others seem to try to get rich from other members.
connect_4
Postby GKandR4CH » Fri Jul 27, 2012 3:00 pm
Don't start this again Andy. PLEASE!!!
All I did was reply with a link to VT who can help.
I can't blame VT for not wanting to share everything as in effect he is running a business now. If he gave everything for free then there is no point in running a business.
It's like calling Vantuner or similar company and asking them to tell you how to tune your van / car thus bypassing them.
I can't share this info to you dude as I don't know and wouldn't want to say something in case it's wrong. I only know brake discs. My axle is bang on and haven't had any grief since Paul set it up.
Yes it cost me, but it was done professionally and right and that is all that matters to me.
I would not want to do this design / technical stuff in case I endangered myself. I'd rather someone / or a company to do it. But that's me.
If you have the ability to do it yourself then go for it!!
GKandR4CH
Postby Drizz » Fri Jul 27, 2012 4:45 pm
Thats perfect connect_4 much appreciated fella. My neighbour is a welder so as long as i do the hard work, and make him tea its all good!
Drizz
Postby connect_4 » Fri Jul 27, 2012 5:04 pm
GKandR4CH wrote:Don't start this again Andy. PLEASE!!!
Stop putting up daft posts and getting people to "guess what relay" etc, if you have some info to help others then share it and stop asking members to "buy a kit from valetech", every time someone asks for info you put up a reference to modyourtransit, valetech says there is no need to move the axle, so what is the alternative then ? - why the secrecy ?
it's getting a bit sad now, all this "PM me for info" etc, i appreciate someone has a business to run but it seems that any piece of help now has to be paid for, are you on a commission or something ?
As far as doing it properly goes, who says we aren't doing it properly ourselves, who gave valetech the divine right in doing it properly, are the rest of us bodgers ? I think not !!!
You are getting on folks nerves with all this reference to valetech every time we have an issue with something, myself on the other hand will always try to help members keep the costs low by doing the work themselves, give the members some credit for their mechanical skills.
Andy
connect_4
Postby connect_4 » Fri Jul 27, 2012 5:06 pm
Drizz wrote:Thats perfect connect_4 much appreciated fella. My neighbour is a welder so as long as i do the hard work, and make him tea its all good!
No problem, be careful though your axle doesn't fall off and you die in a big ball of flames, because you did the work yourself and didn't "get it done properly".
cheers
Andy
connect_4
Postby Drizz » Fri Jul 27, 2012 5:26 pm
cheers
Andy
Any 'fuel the flames' much :lol:
Again much appreciated mate!
Drizz
Postby valetech » Fri Jul 27, 2012 6:03 pm
For a start not all vans can have there axles moved back.
This forum doesn't line my pockets.my company has sold many many kits all over Europe from the website eBay etc
It's all well and good say how you did yours (that's fine),but there is a few different setups ford did.so 1 way will not all ways work on another van.
I have given a lot of time making 1 kit fit all.so I'm not going to give it away.
It's about time you flocked off and stop giving false/wrong info.
You don't even own a connect.
molested by:
19s is how we roll
valetech
Postby Dub-77 » Fri Jul 27, 2012 6:12 pm
I've been members of many forums over the years and I gotta be honest (even if I do get sh*t for it) this is by far the clickiest forum I've been a member of.
I've always been one for helping out others in the forum community as that's what they are there for. GK, I understand Paul is running a business and his gotta make a living but he should stay away with the little comments. You don't see Martyn (vantuner) on here being like that. We all know what Paul does and can do that's why I haven't before earlier today asked how to do it, he obviously know so fair play and if he don't wanna share then fine but no more I know how to do it type comments. I hope Paul does well in his business he puts in the time and research and money to create the thing he does. I for one have had a disc conv kit from him and am very pleased with it.
So bring on the tongue lashing...
Dub-77
Postby C8XY » Fri Jul 27, 2012 10:21 pm
Did my own window tinting! Very easy on the Connect, nice shape and loose rubbers. Turned out really well
Pics:
C8XY
Postby Dub-77 » Fri Jul 27, 2012 10:41 pm
C8XY wrote:Did my own window tinting! Very easy on the Connect, nice shape and loose rubbers. Turned out really well
Im gonna have a go @ my sun strip (Limo Tint) but i think my screen is gonna have to come out first for the rust spots on the roof (HI-TOP) to be properly repaired.
Dub-77
