taz666 wrote:transit connect is 150,000 mls or 10 yrs and ford specify that the chain/belt that runs the pump needs replacing at that time too
Stavros wrote:Normaly cam belt is changet every 60/90 k kilometers not miles!!!! So in miles every 50kmiles will be ok. Cam chain shuld be changed every 180-200k kilometers.
Honey monster wrote:Stavros wrote:Normaly cam belt is changet every 60/90 k kilometers not miles!!!! So in miles every 50kmiles will be ok. Cam chain shuld be changed every 180-200k kilometers.
As Taz666 The FORD TECH,Who is FORD trained and works on Fords and drives a Ford Connect,150,000 MILES or 10 years.
taz666 wrote:oi stavros, im not some spotty teenager who is still learning, ive been working on fords for the best part of 20 years and its as per ford etis that ive quoted the cam belt replacement interval not a guess off the top of my head, i do appreciate that some belts are made of the same material but not all are the same width, on a connect it only runs between the pump and camshaft so its not that long
Wobby wrote: Taz, are the chains down on the schedule for changing at 150k?
