Not going to use them like this but then thought I might hide a button in case needed for any reason ??
yttam84 wrote:whats the idea of them ?? to look chavy been there done that
mike-dyson wrote:Old post but it save making a new one.
I'm wanting to put some day running lights on my van and have then on a switch in the shelf bit under the steering wheel.
Just a few questions...
Were would be a good place to get power from?
Is there any easy access from the cabin to the engine bay to run my cable?
Any help would be great thanks
paul2012 wrote:
They do not have to turn off when headlights are turn onI have factory DRL on my 2012 Vauxhall Insignia & they stay on even when headlamps are on (Athough headlamps turns on automatically)
paul2012 wrote:You could take a 12V+ live feed from the Engine bay Fuse Box from Fuse F22 or direct from Battery & run through a relay & Connect the relay switch wire to pin 4 (GN/YE) on the Headlight switch plug. This way the DRL will come on with ignition is switch on & switched off when headlights are turned on.
