by MrC » Sat Oct 27, 2012 11:43 pm
Still not fixed squeal or belt running off to one side. Couldn't afford to take van into garage in the end.
But did buy the splash shield. Unfortunately I found that it didn't fit around my starter motor properly, so took it back to Ford and exchanged for the air-con version (vans with air-con have more wheels/a longer belt and thus a different shaped shield). Be warned: you don't get the bolts with the shield! They cost an extra 3/4 quid!!!
So far no rain, so can't confirm an improvement as the squealing would always start whenever it rained (and then go on for a day or two afterwards!). Will let you know more after a soak!
TRANSIT CONN T220 L90 2007
