g-man wrote:hiya m8yshould be ok with 8.5's with that offset but might be a bit close on rears to the inner arch......7's would defo clear
valetech wrote:Ford use 18"x7.5j
But most people use the focus st wheel which is 18"x8j
Both have a et45
Both run very close to the rear inner arch felt panel
It's also a case of how low are you going
valetech wrote:first pic is my old van yes,does go lower than that.they are connect alloys 18"x7.5j et45 its around 4"to7" lower on the rear sportvans are lower from factory than a standard connect
second pic is a customer/forum member.
lowered the same as mine and running focus st 18x8j et45
have had no probs with the wheels rubbing
zombiechad wrote:valetech wrote:first pic is my old van yes,does go lower than that.they are connect alloys 18"x7.5j et45 its around 4"to7" lower on the rear sportvans are lower from factory than a standard connect
4" to 7" is a big range relative to vehicle ride height!So an extra inch in width may get close to the inner plastic arch in the rear. Has anyone trimmed this arch or spaced it? What about the front? Rubbing at full lock?
