White smoke, missfire and rattle
Postby norbert-handglider » Sat Jul 14, 2012 8:46 am
I have a 2004 Transit connect LX TDCI 1753cc. Over the last 3 months when starting from cold there is white smoke coming from the exhaust and getting progresively worse. 2 Weeks ago the smoke has got realy bad and there is a missfire at about 1500 revs, also the is a rattle from what sounds like top end bearings. This only happens when the motor is cold and dissapears after a couple of miles or so when the motor warms up.
I have had the injectors overhauled at Colchester Fuel Injection but this has made no difference at all.
Any suggestions please. :?
norbert-handglider
Re: White smoke, missfire and rattle
Postby Dub-77 » Sat Jul 14, 2012 12:50 pm
Have you checked for head gasket failure. But my initial thoughts were injectors. There is a thread on here about a guy who has his injectors overhauled. But still had the same problem. I'm not saying the place who done yours are not good but ...... Have a read of his thread viewtopic.php?f=54&t=108175
Your problem sounds similar to mine and injectors sorted my issues.
Dub-77
Postby 501 » Sat Jul 14, 2012 1:11 pm
Sound like you could have some glowplugs not working, i would first check that you have power at the glowplugs, if that is ok you will then have to check each plug individually.
501
