rear door lock
rear door lock
Postby gaz68 » Mon Jul 30, 2012 10:04 pm
i have a ex national grid lwb connect ,the front and side doors are on the same key but the rear is a new lock fitted by the dealer i bought it off,this lock works fine but when you shut it it locks every time ,so you have to use the key to unlock it every time,how do i over come this ?
gaz68
Re: rear door lock
Postby liteace » Sun Sep 30, 2012 3:58 pm
You may have this sorted by now as its been a long time, I have had to replace the hole locking + handle system on the rear doors of my Connect, there are several different types of lock\ latch, sound to me that you have a slamlock fitted, they use these sort of systems on courier \ delivery vans (not Ford Courier) so the rear door is always locked when its closed
liteace
Re: rear door lock
Postby gaz68 » Mon Oct 01, 2012 10:01 pm
thanks for that mate,and no it's not sorted out yet,so if i have got slam locks fitted can they not be deactivated ?,or am i stuck with them :?:
gaz68
Re: rear door lock
Postby paul2012 » Tue Oct 02, 2012 1:50 am
gaz68 wrote:thanks for that mate,and no it's not sorted out yet,so if i have got slam locks fitted can they not be deactivated ?,or am i stuck with them :?:
Sorry to say, your stuck with em, can't be de-ativated
The lock you require is this one
http://www.ebay.co.uk/itm/FORD-TRANSIT- ... 2ec2124697
Please note :- you have to remove key barrel first ! before removing lock assembly
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
