CONNECT SHUDDER
CONNECT SHUDDER
Postby digisat md » Thu Dec 28, 2006 8:51 pm
ANYONE HAVE A SHUDDER WHEN AT SPEED OR GOING UP HILL. HEADLIGHT SWITCH FLASHES AND SOMETIME VAN CUTS OUT DEAD?
donald hall
digisat md
Postby andy j » Thu Feb 08, 2007 8:09 pm
Hello,
Ive only just joined so you may have sorted out this problem.
I had a similar problem with my T200 LX last year. Whereby I would be driving (at various speeds) and the van who judder and possibly cut out or even cut out and restart.
The problem with mine was the air filter - which had basically collapsed.As it had retained moisture after the engine had been steam cleaned ......The servo pump had failed prior to this, and sprayed oil all over the engine compartment, hence the steam cleaning.
Touch wood....its been fine since!
Cheers.
andy j
