My lowered LWB- HI-TOP
Postby Dub-77 » Sat Aug 18, 2012 8:30 am
Used the axle flip method with front MK1 FOCUS RS Springs. Arse end is low but I've made and fitted adj hangers since just need more photos.
These are pictures before I fitted the adjustable rear hangers.
Hope to get more pics up today.
Cheers
Darren
Dub-77
Re: My lowered LWB- HI-TOP
Postby Adam_84 » Sat Aug 18, 2012 9:02 am
This is the first lwb I've seen lowered, looks good
Adam_84
Postby Dub-77 » Sat Aug 18, 2012 9:57 am
Adam_84 wrote:This is the first lwb I've seen lowered, looks good
Cheers mate
Dub-77
Postby keirv6 » Sun Aug 19, 2012 9:32 am
Looks cool like the wheels
keirv6
Postby Dub-77 » Sun Aug 19, 2012 1:34 pm
Keirv6.... cheers mate.
With the new hangers on:
Was thinking of taking of hangers and putting another set of holes in to drop the back back down slightly or just put some bits in the back of it ;-)
Dub-77
Postby valetech » Sun Aug 19, 2012 1:48 pm
It's nice to see something different.looks nice one thing to be careful of is setting the rear height up. It's a good idea to set it a little higher as it will drop when been driven
molested by:
19s is how we roll
valetech
Postby Kent Discos » Sun Aug 19, 2012 1:56 pm
valetech wrote:It's nice to see something different.looks nice one thing to be careful of is setting the rear height up. It's a good idea to set it a little higher as it will drop when been driven
agree with Vale... give it time to settle, mine took a few days to settle in.
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Media Group - http://www.kentmediagroup.co.uk | Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby Dub-77 » Sun Aug 19, 2012 2:49 pm
Yea I think I'll probably give it a few weeks driving to settle and make my mind up then.
Just need some of the shorter rear shocks gotta save some £££ first.
Thanks for the comments..
Dub-77
Postby Adam_84 » Sun Aug 19, 2012 3:06 pm
Looks spot on now and like you say with bits in the back will help it drop also it's a van so want to keep it useful, has function and form.
Adam_84
Postby Dub-77 » Sun Aug 19, 2012 4:09 pm
Adam_84 wrote:Looks spot on now and like you say with bits in the back will help it drop also it's a van so want to keep it useful, has function and form.
Too true mate
Dub-77
Postby Drizz » Sun Aug 19, 2012 9:38 pm
Hoping to level mine up tomorrow, although id love the front down like the back!
Drizz
Postby Dub-77 » Sun Aug 19, 2012 9:53 pm
I'd have thought with the -60mm drop it would have been more level.
Dub-77
Postby Drizz » Sun Aug 19, 2012 9:56 pm
Itll need to settle a touch. That was pretty much straight off the jack.
Drizz
Postby zombiechad » Mon Aug 20, 2012 4:28 am
I have a LWB Hi-Top too. Those are standard MK1 RS springs in the front? How much lower would you say the front is?
How much did you have to adjust the rear spring hangers? Any pictures?
What wheel width and offset? What size tire? Any rubbing?
Looks good! I will post pics when I get mine done.
zombiechad
Postby Dub-77 » Mon Aug 20, 2012 6:36 am
zombiechad wrote:I have a LWB Hi-Top too. Those are standard MK1 RS springs in the front? How much lower would you say the front is?
The front TBH didnt SEEM to go down loads, when you hold the springs against each other the RS spring is loads shorter but the spring rates must be totally different. I never took specific before and after pics I just ploughed into getting it done :-) I made new hangers with holes Aprox 80mm (centers) apart from orig hole.
Tyre size is 225-40-18 no rubbing and wheels are from a mondeo st. I've got no pics of rear hangers sorry. I might be able to get under and take a few later.
Get yours done and there will be 3 of us hi-tops lowered :D
Dub-77
