EGR cooler bypassing.
Postby gt_addict » Tue Aug 21, 2012 7:52 am
Hi guys,
Could someone tell me what I need to be able to bypass the EGR core on a 2004 90ps tdci t230 please?
Thanks,
Peter.
gt_addict
Re: EGR cooler bypassing.
Postby taz666 » Tue Aug 21, 2012 7:20 pm
just get a piece of copper tubing or a plastic joining piece from b+q or somewhere like that about 3-4 inches long the same size as the internal bore of the pipes, take the 2 pipes off and fit to the copper tubing with jubilee clips
taz666
Ford Technician
Postby gt_addict » Tue Aug 21, 2012 9:03 pm
Cheers taz, would 15mm pipe be alright?
gt_addict
Postby gt_addict » Wed Aug 22, 2012 9:56 am
Also is there any long term affects of bypassing it as I can't afford a new cooler at £371 lol
gt_addict
Postby taz666 » Fri Aug 24, 2012 8:23 am
as long as its a snug fit in the pipe yes and dont know about long term effects to be honest, ive only done them as a short term fix
taz666
Ford Technician
Postby gt_addict » Fri Aug 24, 2012 11:43 am
Lovely stuff cheers taz.
gt_addict
Postby Wobby » Wed Aug 29, 2012 8:29 am
My EGR cooler has been bypassed for a long time, but i've also blanked the EGR so i thought bypassing it was the way to go.
My mileage is 227,000 and i don't think its caused any issues.
Wobby
Postby gt_addict » Wed Aug 29, 2012 9:30 am
Wobby wrote:My EGR cooler has been bypassed for a long time, but i've also blanked the EGR so i thought bypassing it was the way to go.
What did you bypass yours with as I'm struggling to find something the right diameter that won't crush when I do the jubilee clips up. I don't want to have to get hose joiners, I just want a bit of pipe that fits straight in.
I've also blanked my EGR aswell.
I've seen a second hand cooler on eBay (221043810691) from a t230 lwb but it says it's from a 73hp model. I didn't think they put that engine in the lwb? It looks the same though, reckon its worth a shot?
gt_addict
Postby Wobby » Wed Aug 29, 2012 11:55 am
Bloody hell thats £50 !!
Its a while ago, i'll have alook in an hour or so (if the rain stops!)
Also i may have a spare cooler off my other engine
Edit....
Mines a LWB and had a 75ps engine!
Is it leaking?
Wobby
Postby gt_addict » Wed Aug 29, 2012 12:13 pm
Yea a second hand one is £50 a new one is £371 from fords.
I can't see any leaks on the engine, water pump or radiator. There's no water in the oil so the only place I can think of (after reading various posts on here) is the EGR cooler.
gt_addict
Postby Wobby » Wed Aug 29, 2012 1:11 pm
How much are you losing?
Just looked at mine and was completely amazed its still got it's pipes attached :lol: Must have had trouble getting a decent seal so ended up with them back connected!
I've found my spare cooler if you want it posting down pm me your name and address and i'll get it sent off. I could do with one back though, so if you could post me the one you don't need back. Even if it leaks i'll still have it as i want to use it to fabricate something to do away with the silly thing......
Wobby
Postby gt_addict » Wed Aug 29, 2012 5:49 pm
I'm losing the max to min mark on the resovoir over 5 days. It's not a lot really only about a mug full over 200 miles.
I'd like to make sure it's that's that leaking first so might well get a couple of hose joiners from the motor factors as join the hoses if that's what you've done?
gt_addict
