Key fob worn out
Key fob worn out
Postby lightning » Sat Aug 25, 2012 11:49 pm
The lock button on my remote fob has worn out and is hard to use.
How can I fix this, do I need to buy a new remote fob, and then get it coded to the van somehow? Are the ebay ones OK?
lightning
Re: Key fob worn out
Postby gt_addict » Sun Aug 26, 2012 12:13 am
Is it the square fob that's separate from the key? If so the eBay ones with the blue buttons are fine. I bought one when I first got my van and it's been fine for the past two years. Just remember to code all the fobs at the same time so you've got the old one as a spare ;)
You have to sync/code them all in one go not at different times ;)
gt_addict
Postby g-man » Sun Aug 26, 2012 5:27 am
or get a new all in one cut and coded........lot better :wink:
g-man
Postby bigjohnthomas » Sun Aug 26, 2012 7:13 am
3x microswitches Ford remote fob three pounds forty pence or best offer mingebay :D
bigjohnthomas
Postby bigjohnthomas » Sun Aug 26, 2012 7:30 am
There's someone that fits them too
Better than a rehomed one you don't know whos been licking it
bigjohnthomas
Postby lightning » Sun Aug 26, 2012 11:21 am
Thanks l have seen the microswitches on ebay, my remote is the rounded one with key in it, l will order some of those and fit them.
lightning
Postby bigjohnthomas » Sun Aug 26, 2012 11:32 am
Those switches are for the separate key fob thing I think :?
bigjohnthomas
Postby lightning » Sun Aug 26, 2012 1:43 pm
I did wonder that, so have emailed the seller to see if mine are available.
Can I use the older type separate remote with my 2008 Connect?
lightning
Postby lightning » Sun Aug 26, 2012 10:54 pm
The microswitches are different, but they also sell the correct type for my remote, so I ordered a set.
lightning
Postby lightning » Wed Aug 29, 2012 10:38 pm
Parts arrived today, fitted in 10 minutes and now the remote is as good as new for £6.
Takes a steady hand and a fine tipped low wattage soldering iron to do the job though, or you risk damaging the circuit board.
lightning
Postby bigjohnthomas » Thu Aug 30, 2012 6:19 am
8) click atyclick and you know where its been too :lol:
bigjohnthomas
