How long before I have to get my cheque book out?
Postby lightning » Sun Aug 26, 2012 10:51 pm
My Connect TDCi engine idles badly (lumpy) when cold but is OK once it has warmed up a bit.
I know this can be the start of injector issues but the van does drive fine with no other issues. Can I leave it until it comes up with a warning light, and will it do any harm?
I don't fancy spending £1,000 on it at the moment!
Is there anything else that can cause this fault? It's done 51,000 miles.
lightning
Re: How long before I have to get my cheque book out?
Postby dieselboy1978 » Sun Aug 26, 2012 11:34 pm
What year is the connect for a start?
When did it have a full service last?
Have you done a fault read with a decent diagnostic machine?
Bank account emptied by
DELPHI
dieselboy1978
Postby lightning » Mon Aug 27, 2012 12:00 pm
It's a 2008. It was serviced in October 2011 by Ford and they replaced one injector as it had "leakback" Even though I had not noticed any issues.
They also replaced the sump, again no problems reported, I think they were trying to make a bit of money before the warranty ran out.
To be honest I don't think the "service" included much more than an oil change.
Since the service it's done about 10,000 miles and the lumpy idle when cold has been there for a while.
I booked it in to Ford next week for a "free vehicle health check" so hopefully they will plug it in to the computer and see if there are any faults showing up.
lightning
Postby dieselboy1978 » Mon Aug 27, 2012 8:40 pm
First thing I would be doing is read of the PCM to see if any fault codes are present on the memory.
I would be expecting You to be changing a fuel filter replacement.
Just make sure it is a good quality filter, worth paying for a FORD one to be honest.
DELPHI
dieselboy1978
Postby lightning » Tue Aug 28, 2012 5:33 pm
Thanks, can you tell me where the fuel filter is located and if I could change it myself?
lightning
Postby dieselboy1978 » Tue Aug 28, 2012 5:37 pm
Should be located either on left hand side of engine bay by bulk bead or at end of rocker cover on right hand side
DELPHI
dieselboy1978
Users browsing this forum: metalworker0
