If it's not un-balanced wheels, what is it?
Postby hat » Fri Aug 31, 2012 3:01 pm
Re: 2006 Connect 1.8.
I'm experiencing the typical wobble through the steering wheel that you get when the wheels are out of balance. I've had the wheels re-balanced with no improvement.
I'd appreciate any suggestions as to what else it might be.
hat
Re: If it's not un-balanced wheels, what is it?
Postby dieselboy1978 » Fri Aug 31, 2012 3:52 pm
Investigate and check the driveshafts.
Very common fault that causes alot of vibration and when gets really bad can cause power reduction.
Bank account emptied by
DELPHI
dieselboy1978
Postby valetech » Fri Aug 31, 2012 6:37 pm
check n/s/f wheel bearing
molested by:
19s is how we roll
valetech
Postby SWtechnologies » Fri Aug 31, 2012 8:15 pm
i had the same problem! changed both drive shafts and sorted....
SW technologies
SWtechnologies
Postby big bad james » Fri Aug 31, 2012 8:41 pm
i had focus with the same problem it turned out to be the diff after i had changed the wheels and driveshafts
big bad james
Postby hat » Tue Sep 04, 2012 5:58 am
Thanks everyone! It was the r/h d'shaft.
I've changed a few on this van during its 321000 miles, but hadn't experienced those symptoms before from a d'shaft, hence my query.
hat
Postby airconman » Tue Sep 04, 2012 5:52 pm
321000 miles wow thats a fair haul haha
airconman
