Changing seats in transit connect
Postby Chrissyronald » Fri Sep 14, 2012 10:51 pm
Hi all.
Just got my transit connect 57 plate.
And I am wondering if the fiesta mk6 ST seats will fit into mines
Any help will be great
Cheers
Chrissyronald
Re: Changing seats in transit connect
Postby dieselboy1978 » Fri Sep 14, 2012 11:13 pm
In theory you can fit whatever seats you want.
Its how you put them in and fix them is the important part.
Bank account emptied by
DELPHI
dieselboy1978
Postby Mylee » Sat Sep 15, 2012 10:55 am
There are no direct fitment seats from other ford models.
Mylee
Postby Adam_84 » Sat Sep 15, 2012 12:10 pm
Is it safe to use UNi-strut and appropriate nuts and bolts etc to fit them in?
Adam_84
Postby Mylee » Sat Sep 15, 2012 5:40 pm
Adam_84 wrote:Is it safe to use UNi-strut and appropriate nuts and bolts etc to fit them in?
It's how my ST seats are fitted, I asked the guy at MOT time and he was fine with it.
Mylee
Postby Adam_84 » Sat Sep 15, 2012 7:01 pm
Did you use zebidee things in the unistrut?
Adam_84
Postby Mylee » Sat Sep 15, 2012 10:35 pm
Adam_84 wrote:Did you use zebidee things in the unistrut?
No mate, unistrut is inverted, so seats bolt to the elongated holes allowing for adjustment, then use a bolt throu a zeb clip with the spring removed. Very solid.
Mylee
Postby Adam_84 » Sat Sep 15, 2012 10:46 pm
Nice one mate
Adam_84
Postby westers » Sun Sep 16, 2012 10:55 pm
I went for the 50x50 box steel approach :lol:
WESTERS T220 LX connect
westers
Postby dieselboy1978 » Sun Sep 16, 2012 11:26 pm
My seats bolts to made 1/4 inch thick plate that is bolted to the original bolt holes in the floor with high tensile 14.9 cap head screws. Then the seats are bolted again to 14.9 high tensile cap head screws to the plate.
Bearing in mind original bolts are only 8.9 torx so i have uprated the fixings so no bodging this end.
All speced up by professionals.
Too worried about seats ripping out of floor or bolts failing.
DELPHI
dieselboy1978
