I have a transit connect t230 1.8 tdci which is misfiring and smokes white-grey. I have put new injectors in cleaned fuel lines checked pipes for splits new fuel fillter, air fillter, any suggestions? Could it be the fuel rail?
Fuel rail no. Are these injectors from a genuine Dlephi Agent or copy or second hand. I would be re checking injectors or checking the switching time (milli seconds) on the injectors. If they are 100% ok then i would be removing the high pressure fuel pump. Possible fault could be the venturi or the relief valve.
We have programmed the injectors to the ecu got the injectors from gap heds autoparts Birmingham my old ones reconditioned. I have loads of fuel pressure from pump. So first I should buy a: New crank sensor New camshaft sensor
If the vehicle runs it isnt camshaft or crankshaft sensor. If camshaft sensor fails vehicle will onky fire and cut out or not run at all. Working as a diesel fuel injection specialist i would be removing injectors and sending to a delphi diesel agent and getting injevtors tested on the the authorised CRiPC test bench.
They have come from a registered company got 12000 miles warranty or 12 months whichever comes first. It has to be something befor the injectors as it fluctuates between the two middle injectors if you take electrical connector of to see if there is a difference in running whilst idling. Cheers Richard
Just found out cilinder no has minimal compression problems tried 3 sets of injectors same one all the time. Any body know where I can get new and I mean new engine from? Ivorsearle have on but bit pricey? Cheers Richard
