My 2003 Transit Connect Project (Pic Heavy)
Postby paul2012 » Sun Sep 23, 2012 8:14 pm
Here is what I have done to my 2003 Transit Connect so far - I still have more work to do, so updates will follow 8)
If you have any questions Please ask
This wiring info is usefull for people who wish to fit the connect elec windows & Heated elec mirrors into the mk1 connect
The Pins in the door loom sockets are clearly numbered from 1 to 20, the sockets are located in the A Pillars (door looms just simply plugs into them)
Please Note this the wiring details for fitting the elec windows & heated elec mirrors removed from connect 2006 onwards (NO SEPERATE RELAY IN DRIVERS DOOR) into a mk1
DRIVERS DOOR SOCKET - PIN CONNECTIONS
PIN 9 12V+ FOR ELEC WINDOWS
PIN 12 12V+ FOR ELEC MIRRORS
PIN 20 12V+ FOR HEATED MIRRORS
PIN 11 LINK TO PIN 11 ON PASSENGER DOOR SOCKET - FOR ELEC WINDOW
PIN 5 LINK TO PIN 5 ON PASSENGER DOOR SOCKET - FOR ELEC WINDOW
PIN 13 LINK TO PIN 13 ON PASSEENGER DOOR SOCKET - FOR ELEC MIRROR
PIN 15 LINK TO PIN 15 ON PASSENGER DOOR SOCKET - FOR ELEC MIRROR
PIN 16 LINK TO PIN 16 ON PASSENGER DOOR SOCKET - FOR ELEC MIRROR
PASSENGER DOOR SOCKET - PIN CONNECTIONS
PIN 912V+ FOR ELEC WINDOWS
PIN 11 LINK TO PIN 11 ON DRIVERS DOOR SOCKET - FOR ELEC WINDOW
PIN 5 LINK TO PIN 5 ON DRIVERS DOOR SOCKET - FOR ELEC WINDOW
PIN 13 LINK TO PIN 13 ON DRIVERS DOOR SOCKET - FOR ELEC MIRROR
PIN 15 LINK TO PIN 15 ON DRIVERS DOOR SOCKET - FOR ELEC MIRROR
PIN 16 LINK TO PIN 16 ON DRIVERS DOOR SOCKET - FOR ELEC MIRROR
Fuse 55 25A for elect windows - CONNECT TO PIN 9 ON DRIVERS & PASSENGER DOOR SOCKETS
Fuse 47 5A for elect mirrors - CONNECT TO PIN 12 ON DRIVERS DOOR SOCKET ONLY
Fuse 50 7.5A for heated mirrors - CONNECT TO PIN 20 ON DRIVERS & PASSENGER DOOR SOCKETS
Getting there but not finished yet :lol: :lol:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: My 2003 Transit Connect Project (Pic Heavy)
Postby ff1976 » Sun Sep 23, 2012 9:59 pm
Looking good so far! :D
ff1976
Postby paul_h » Mon Sep 24, 2012 11:17 am
Looking great. Apart from the seats uve done every mod I fancy doing lol Not overly keen on the orange but each to their own :)
paul_h
Postby Honey monster » Mon Sep 24, 2012 1:49 pm
Like the seats but the welding looks a bit sh*t, You sure they are safe.
Honey monster
Postby rokit » Mon Sep 24, 2012 5:59 pm
Can you give me a bit advice, how do I connect the wire from pin 12 for the electric mirrors to the fuse box? Which wire is it from the back of the fuse box?
Cheers!
rokit
Postby paul2012 » Mon Sep 24, 2012 6:18 pm
Honey monster wrote:Like the seats but the welding looks a bit sh*t, You sure they are safe.
seat are from a Mondeo mk2 ghia - both are heated seats & drivers seat is elec :D
The welding is inside & out of the 1/4" thick steel pillars on the front mounts & then ground down (with angle grinder) Yes they are safe, Even took a sledge hammer to them just to make sure :idea:
The rear mounts are just 1/4" thick steel plate so no welding needing there 8) & seats bolted down with high tensile steel bolts.
paul2012
Postby Hotwheels » Mon Sep 24, 2012 6:30 pm
Briliant job what year is the front bumper and is it sreight forward fitting it also what do you use your van for cheers.
Hotwheels
Postby paul2012 » Mon Sep 24, 2012 6:33 pm
rokit wrote:Can you give me a bit advice, how do I connect the wire from pin 12 for the electric mirrors to the fuse box? Which wire is it from the back of the fuse box?
Cheers!
Here is the wiring diagram
You will need a wire of suitable ampage to run from pin 12 to fuse panel.This needs to be connected the to orange/yellow wire on connector C15 for fuse F47 (5 amp)
Use a multimeter to check continuity between fuse F47 & the Orange/yellow wire (make sure multimeter is on the ohms seting & ignition turned off) if you have the correct wire the reading should be zero (0000)
Connect mirror 12V+ wire from pin 12 to it.
paul2012
Postby paul2012 » Mon Sep 24, 2012 6:39 pm
Hotwheels wrote:Briliant job what year is the front bumper and is it sreight forward fitting it also what do you use your van for cheers.
The front bumber is brand new, its fitted to mk2 connects from 2006 - 2009.
As you can see it also fits the early mk1 as well, It just bolts straight on no problem. If planning to fit the mk2 bumper you will also need to replace both front plastic wheel arch trims as well (again just fits straight on)
paul2012
Postby paul2012 » Mon Sep 24, 2012 6:43 pm
paul_h wrote:Looking great. Apart from the seats uve done every mod I fancy doing lol Not overly keen on the orange but each to their own :)
Thx
Yes that slam panel is abit bright :lol:
But it will get sprayed up nexted year, Planning on respraying the van to performance blue 8)
paul2012
Postby Hotwheels » Mon Sep 24, 2012 6:51 pm
Hi how much would it cost for the bumper plastic wheel arches and slam panel and who suplies them cheap cheers.
Hotwheels
Postby paul2012 » Mon Sep 24, 2012 6:58 pm
They are normally found on ebay, But if you prefere new, I got mine from EMG ford (I have an account with them so I get parts at trade price)
they are also available new from here :-
http://www.hamtunespares.co.uk/
http://www.crashrepairparts.com/parts/m ... r?_ts=1077
paul2012
Postby rokit » Mon Sep 24, 2012 7:12 pm
Thanks for the info!!
rokit
Postby irish.T220 » Mon Sep 24, 2012 8:18 pm
Nice work on the van :D Are you using a heating element in the seats ?
irish.T220
Postby paul2012 » Mon Sep 24, 2012 8:27 pm
irish.T220 wrote:Nice work on the van :D Are you using a heating element in the seats ?
Thankyou
Yes I will be, Wiring has been added & connected to fuse panel, just waiting for heated seat switches to arrive from EMG Ford.
they were supposed to come togehter but wiring turn up first :roll:
paul2012
