Awkward/prolonged start up?
Postby mekmanuk » Tue Oct 09, 2012 7:33 pm
My 53 tdci (bought recent) and been in my garage having work done. Ive noticed its a little awkward\to start when cold? i notice the heater plug light goes out pretty quick?
All glow plugs are new and working fine, even fitted a push button thinking this would do the trick but to no avail.
it fires up after 15 secs or so but dont want the cold weather to cause me probs? i have a brand new battery fitted also.
not sure what i can do if anything to try to resolve this problem, any advice or ideas would be gretaly appreciated.
forgot to say she runs fine when running!
mekmanuk
Re: Awkward/prolonged start up?
Postby blue estate » Tue Oct 09, 2012 7:37 pm
Try a new starter and check the timing belt as my old 04 focus was the same and when i changed the starter and re did the belt as it was not set right the car started on the button every time :wink:
p/s does it start better when it's hot ?
blue estate
Postby liteace » Tue Oct 09, 2012 7:38 pm
Pull one of the glows out and check the part number is 100% correct for your van, have you checked the voltage at the glows when pressing your button
liteace
Postby Capovan » Tue Oct 09, 2012 7:51 pm
My 51 plate tdci focus was the same and is a common prob with this engine. the glow plug light would stay on for one second only which is controlled by the GM module apparently..After many searches on this i was advised to put a stronger battery on with a cold cranking amps of 750 instead of the 550 it had on and it was a lot better.
Hope that helps :D
Capovan
Postby ginsters » Tue Oct 09, 2012 9:18 pm
battery and clean up the terminals
the red ones go faster...
53 plate 75ps lwb
vantunner remap and all the other jazz
unfortunately the doors aint as great as the caddy
north wales where the the men are men and the sheep are scared!
ginsters
Postby BLUECONNECTION » Wed Oct 10, 2012 1:12 am
our tdci did this, changed the glow plugs, fitted a bigger battery and swapped the starter but it still did it, did an injector leak off test and they were all over the place, sent the injectors off for a referb and she now starts in less than 2 seconds on a cold morning :D
BLUECONNECTION
Postby mekmanuk » Wed Oct 10, 2012 7:24 am
Thanks for the replies fellas, the glow plugs are all new, i will check them thou to see if there the right ones. Ill also look at the battery. starts ok when hot.
I had all new injectors fitted, when you mention the timing i assume you mean the timing chain?
mekmanuk
Postby Capovan » Wed Oct 10, 2012 8:34 pm
Hi, not the timing chain but the timing belt. i would invest in a haynes manual for ya van and you will have a clearer picture of things..the timing chain ( Gemini )runs from the crank to the injection pump and generally dont need replacing unless very high mileage. What size is your battery ?
Capovan
Postby mekmanuk » Wed Oct 10, 2012 9:52 pm
the batter is brand new, checked with supplier and correct one (100) 650 amp i think. i know the timing chain and belt, i will check it aswel. I do know the starter on it is off a 51 plate focus when the engines hot it seems to spin over better than when cold so im suspecting maybe a lazy starter?
mekmanuk
Postby Capovan » Wed Oct 10, 2012 10:05 pm
Before you start it turn ignition on and off a few times and the glow plugs will give it a boost if its cold outside
Capovan
