bulkhead
bulkhead
Postby cdo1uk » Fri Oct 12, 2012 6:47 pm
im after a bulkhead, but not the original, cos i want it to straight down... has anyone got one or can anyone make me one... i HATE wood work. im in Kent by the way.... :mrgreen:
cdo1uk
Re: bulkhead
Postby tez » Fri Oct 12, 2012 7:45 pm
google this firm m8 them mk @sellthem as well mkply lining :D
tez
Re: bulkhead
Postby cdo1uk » Sat Oct 13, 2012 12:21 pm
sorry, i cant work out what you mean... :?
ive looked up all you have said and i cant find anything like it.
cdo1uk
Re: bulkhead
Postby tez » Sat Oct 13, 2012 2:21 pm
cdo1uk wrote:sorry, i cant work out what you mean... :?
e bay this numder m8 https://www.ebay.co.uk/itm/110957085633&seller=&toolid=10018&46193995" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/110957085633 :D
tez
Re: bulkhead
Postby theredcaddy » Sat Oct 13, 2012 3:21 pm
Remember Plywood cargo partitions are no where near as good as a steel one in an accident: :shock:
The following conclusions have been determined based on the results of the drop tests onto typical
partitioning system materials.
• Regular plywood sheet up to 18mm thick provides poor penetration resistance and restraint of
objects of small cross section i.e. with a cross sectional area less than 50mm squared.
• Steel sheet with a minimum thickness of 1.5mm provides good penetration resistance and
restraint of objects of small cross section i.e. with a cross sectional area less than 50mm
squared.
• Cargo loaded into vans with sharp ends should be adequately restrained or loaded so as to
limit the likelihood of them penetrating the partitioning system.
Connect T230
theredcaddy
Re: bulkhead
Postby CamsTrans » Sat Oct 13, 2012 3:24 pm
Build shelves on the bulkhead; that's got to help :lol:
58 Transit Connect swb LR 75 (Gone)
08 Mk7 Transit Limited swb LR 140 (Gone)
14 Transit Custom Limited swb 125 8)
CamsTrans
Re: bulkhead
Postby cdo1uk » Sat Oct 13, 2012 8:18 pm
already spoke to them... they wont deliver and wont sell just the bulkhead. i already have the other bits.
cdo1uk
Re: bulkhead
Postby tez » Mon Oct 15, 2012 1:56 am
ok m8 it was worth a go :D
tez
