tomjbirch wrote:hi, i have a 2006 (56plate) connect and want to try and see if i can make it look like a new model, what will i need to get in order to do this, and will i be able to change the dash to make it look like the new on aswell??
Yes it can be done, check here
viewtopic.php?f=54&t=110324&start=30Valetech has already done it to a 2004 connect.
If your is the mk1 connect (ford badge on bonnet) 2003 -2006
Then you will require later front bumber complete with both grills & rubber spoiler for bumper bottom , Both front plastic wheel arch trim & Later Key barrel for bonnet lock (the later one is longer !)
if yours is the mk2 connect (ford badge on grill) 2006 - 2009
Then you will require later front bumber complete with both grills & rubber spoiler for bumper bottom - Thats it. Very easy mod everything just bolts / clips on.
Yes the later dash will fit too, Just will bolt straight in. Remember to get the steel support / frame the dash is bolted too, as it is different to the one you have currently fitted !
The only downside is the wiring loom, Mk1 connects are straight forward easy to mod, Mk2 connects have a CANBUS system fitted, (where every electrical component talks to each over) - The CANBUS itself is built into the fuse panel behind glovebox.
The new connects also have a CANBUS system as well. Most of the original loom on a mk2 may be moved & relocated for the later dash, The problem will be the instrument panel (clocks) They have to be reprogramed to your vehicle via CANBUS.
The easy option is get the wiring diagrams for the latest model & compare them to the wiring diagrams for your connect.
If you have the mk1 connect the only way it can be done is change the wiring loom & elec components etc. Basically you will be installing the CANBUS system & everything to go with it (But everything electrical must be from the same vehicle)
I was thinking of doing this as my next project
