connect sounds like a land rover
Postby andy dunn » Wed Oct 24, 2012 6:06 pm
just thought i would drop a line,in the hope someone can sort this noise out.my van is a 2007 (75)ive changed both drive shafts,checked and double checked the wheel bearings,but it still sounds like a off road land rover in the cab,i was sure it had to be a wheel bearing but there is no play or grinding noise when i check them,makes no diference if i put clutch in or free wheel ,doesnt change noise when i corner,HELP its doing my head in :
andy dunn
Re: connect sounds like a land rover
Postby blue estate » Wed Oct 24, 2012 6:11 pm
Have you tryed swapping the front wheels for the back as it could be the tyres
blue estate
Postby g-man » Wed Oct 24, 2012 7:19 pm
i'd check the n/side bearing again
g-man
Postby andy dunn » Wed Oct 24, 2012 7:27 pm
i only checked them yesterday,not the slightest movement or noise,can they bo shot but do not show signs of wear,its getin louder by the week
andy dunn
