8x4 sheets in LWB? help!
Postby Benbristol » Mon Oct 29, 2012 3:08 pm
Hi all,
Looking at buying a LWB in order that i can get, on the rare times I need to, 8x4 sheets in.
Thing is, the description for getting these in is 'diagonally'. Ideally, I want to rack out the back so I'll have quite wide shelving all along the driver's side for all my tools and consumables. Will the boards still fit in?
If anyone can help or, and I'm pushing it here, post a picture of 8x4 sheets in the back of a Connect that would be great.
Many thanks.
Benbristol
Re: 8x4 sheets in LWB? help!
Postby Dagenham Dustbin » Mon Oct 29, 2012 3:59 pm
If you shelve up to the rear doors, they wont go in, its a tight fit , but if you make your shelf with an angle at the door end , you could get away with it.
Dagenham Dustbin
Postby Benbristol » Mon Oct 29, 2012 7:41 pm
Thank you Dagenham Dustin.
Looks like I'm back to the drawing board. I had decided on a Connect LWB as the folding down passenger seat is such a clever idea and I'm surprised no other manufacturer has done it. I have to rack out a large area of the van I buy as i've got a lot of tools and consumables but not enough that it justifies a full size transit. The Connect seemed like the only choice but if I can't get 8x4 sheets in without sacrificing a significant part of the loading area I'm going to have to start thinking from scratch!
Benbristol
Postby Beegly » Mon Oct 29, 2012 8:42 pm
a SWB full size transit isn`t that much bigger than a LWB connect, imo
Mondeo 130 TDCI - personal use
30t mobile crane - for work
2004 T280 125 TDCI, 183,000 miles. sold
'96 Citroën ax, 58ps. saved me over £1500 in diesel. SOLD, replaced with
2001 Citroen saxo 1.5 d
Beegly
Postby Benbristol » Mon Oct 29, 2012 8:55 pm
...Just to complicate it I often park in multistory carparks so need to keep the height down. Im an domestic electician who doesn't need a huge load area but does the odd building job so need to carry sheets. I don't think anyone makes a van for me !
Benbristol
Postby Dagenham Dustbin » Mon Oct 29, 2012 8:58 pm
You can get a nice roofrack for the LWB connect that wilol accept 8x4's. 8)
Dagenham Dustbin
Postby westers » Mon Oct 29, 2012 9:02 pm
what about if you start your racking so far off the floor and suspend it from the sides so you could slide sheets inside flat on the floor? i have a feeling when i plyed my floor an 8x4 sheet slid exactly between the wheel arches on my SWB, this is what im going to go for on my next van, fed up of having to roof rack it every time i need a sheet! :lol:
WESTERS T220 LX connect
westers
Postby Benbristol » Mon Oct 29, 2012 9:27 pm
Westers -
Yeah, it's fit width but not nearly on the length. That's why I was going for the Connect with the sit flat passenger seat that extends the length so the sheet would fit in (or a triple ladder). I don't want a roof rack as the van wouldn't then fit in a multi storey
Benbristol
Postby merc muncher » Tue Oct 30, 2012 9:39 am
Just something to think about, with an 8X4 sheet you will probably be blocking your near side view, something the boys in blue would just love to have a little chat about with you.
merc muncher
Postby Lefty64 » Tue Oct 30, 2012 3:53 pm
Benbristol wrote:Hi all,
Many thanks.
YOU CAN DO THIS, AS I'VE DONE IT WITH 3 SHEETS OF THIN MDF. 8'X4' (NOMINAL) SHEETS ARE ACTUALLY A BIT SMALLER AT 2.4M X 1.2M.
IN THE LWB THERE'S A 1.5M X 2M FLOOR SECTION EXTENDABLE BY THE LHS FOLDING SEAT, WHICH FOLDS FLUSH TO THE FLOOR
ONLY POSSIBLE WITH THE FOLDING MESH BULKHEAD. FITTED DIAGONALLY, THEY END UP PRESSED UP AGAINST THE 'B' PILLAR, AND CAN BE RETAINED BY THE SIDE SECTION OF THE ADJOINING OVERHEAD RAFTER.
SIDE VISION ISN'T OBSCURED. NO OTHER 'COMPACT' VAN HAS THE HEIGHT & FLOOR SPACE TO DO THIS.
HOPE THIS HELPS.
PS.
YOU'LL NEED TO SET UP YOUR DRIVER SIDE RACKING TO END AT THE REAR END OF THE WHEELARCH, SO CHECK THIS OUT BEFORE YOU FIT IT.
2007 T230LX LWB (110PS) with aircon.
Vans are designed for people with imagination. Cars are so limiting ... what can you do with them?
Lefty64
Postby ginsters » Tue Oct 30, 2012 6:45 pm
i have a bar that goes over the headrest and they rest up there and down to the floor at the back
the red ones go faster...
53 plate 75ps lwb
vantunner remap and all the other jazz
unfortunately the doors aint as great as the caddy
north wales where the the men are men and the sheep are scared!
ginsters
Postby westers » Tue Oct 30, 2012 7:27 pm
Ah I see! I thought with the Lwb there might have been enough space :Lol:
westers
Postby vanman46 » Tue Oct 30, 2012 10:43 pm
Does anyone know if you can get a rack to fit on the side like the guys who carry glass have ?
Connect 200 swb
Focus Airbox Mod
K&N Filter
Vantuner Remap
The Future's Bright , The Future's Orange
vanman46
Postby JAMESCZC » Wed Oct 31, 2012 11:02 pm
I may be wrong but I am sure a LWB high top connect is taller than a small transit. Put a roof rack on the connect and you wont get into many carparks ( ive tried).
JAMESCZC
Postby knighty1981 » Thu Nov 01, 2012 2:26 am
a lot roof transit will fit into most multi story car parks no problem... and an 8x4 sheet fits easy in the back...
even easier if you keep your shelves off the ground a bit - then you can put the sheets flat on the floor ;)
knighty1981
