dropping the oil
dropping the oil
Postby gaz68 » Tue Nov 06, 2012 4:46 pm
just a quick one,i have a connect tddi (55 plate),do i have to remove the oil filter from underneath the van ?,or will it sqeeze out from the top ?,on my little courier it was possible from the top just.
gaz68
Re: dropping the oil
Postby blue estate » Tue Nov 06, 2012 7:09 pm
Jack up drivers side take wheel off it on the back corner of engine
blue estate
Postby taz666 » Tue Nov 06, 2012 8:11 pm
or remove the bolt that goes up through the gearbox torque restrictor through the subframe and pull the engine forward till you hear a clunk, then the filter will come out between the driveshaft and rack/subframe
taz666
Ford Technician
Postby gaz68 » Tue Nov 06, 2012 9:06 pm
thank's for the info chap's,cheer's gaz :wink:
gaz68
