04 connect O/S rear wiring loom ???????????
Postby elliott1982 » Thu Nov 08, 2012 7:20 pm
First post here and wondering if someone can help. Central locking was playing up found the common spit wire from door bending it and have new one on order from breakers. Have removed door pannel and found the plug one end but am unsure how far back is the other end of the loom? Do I need to remove side panels inside van or is it near light cluster, basically how do I remove it. Cheers for any advice and time saved my helping.
elliott1982
Re: 04 connect O/S rear wiring loom ???????????
Postby liteace » Fri Nov 09, 2012 4:47 pm
when I took the rear lamp out of mine the other day Im sure I saw the loom inside there, there again I could no have does, take the lamp out and have a look, its only 2 plastic thum nuts on the inside to remove it
liteace
Postby Ott83 » Tue Nov 13, 2012 12:29 am
liteace wrote:when I took the rear lamp out of mine the other day Im sure I saw the loom inside there, there again I could no have does, take the lamp out and have a look, its only 2 plastic thum nuts on the inside to remove it
Yes that's where it is, behind a small black steel cover, which needs the retaining pot rivets drilling out to get access
Transit Connect parts available here:http://stores.ebay.co.uk/VanBits4U
Ott83
Registered Trader
Registered Trader
