rob19 wrote:hi, can anyone help, i have a Transit Connect and the ABS warning light is not illuminating when the ignition is switched on. Fuses are all ok, is there a relay? if so does anyone know where it is? any help or advice will be appreciated, thanks Rob
rob19 wrote:thanks for reply, it has got abs 57plate abs fitted as std from 04
blue estate wrote:Have you checked your reg in etis?
Dub-77 wrote:rob19 wrote:thanks for reply, it has got abs 57plate abs fitted as std from 04
Really ?? I didnt know that. As i asked does the abs kick in or does it skid?
Dub-77 wrote:Dub-77 wrote:rob19 wrote:thanks for reply, it has got abs 57plate abs fitted as std from 04
I give up
valetech wrote:i fill your pain
