What tyre pressure for the transit connect
Postby Hotwheels » Fri Nov 16, 2012 10:07 pm
What tyre pressure for the transit connect with the standard 15" wheels cheers.
Hotwheels
Re: What tyre pressure for the transit connect
Postby paul2012 » Fri Nov 16, 2012 10:16 pm
Hotwheels wrote:What tyre pressure for the transit connect with the standard 15" wheels cheers.
Depends on what brand of tyres you have fitted
It should tell you on MAX PSI on the tyre side wall :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby gt_addict » Fri Nov 16, 2012 11:23 pm
I usually put around 40psi in mine. Max pressure on my pirellis on the back are 55psi I think and the new conti winter ts850's going on the front say max pressure 50psi.
gt_addict
Postby lightning » Sat Nov 17, 2012 12:46 am
According to the book
light loads front 32 rear 38
Fully laden front 36 rear 42
That is for the T200
lightning
Postby supZ » Sat Nov 17, 2012 2:58 am
the MAX is the MAX it can take not what you should run them at :wink:
and brand doesnt matter much either, pressures are pretty standard across the board, just differ by use. (presuming the tyre is for the same purpose as another)
pressures are more vehicle dependant and recommended pressures are normally found in the handbook. (as mentioned above)
2004 Connect LWB TDCi - progress
supZ
Postby Marty.H » Sat Nov 17, 2012 6:50 pm
Marty.H
