transit connect dual fuel
Postby dayveyboyb » Sun Nov 18, 2012 1:25 pm
At what point do you switch over to lpg , should you be staitionary or can you do it while moving , and does the engine need to be warmer before switching , i ve had so much conflicting info . :shock:
dayveyboyb
Re: transit connect dual fuel
Postby blue estate » Sun Nov 18, 2012 1:51 pm
It won't switch over till the engine is at the right temp any way ,and if selected it should swap automatically
blue estate
cron
