insulation / condensation
Postby Capovan » Thu Nov 22, 2012 8:12 pm
Evening all
looked at this topic on the forum as iam after ideas to stop the condensation in rear of van. what has worked the best etc
cheers
Capovan
Re: insulation / condensation
Postby Marty.H » Thu Nov 22, 2012 8:37 pm
this is the rear of my van and i don't suffer any condensation
ply lined and acoustic carpet
Marty.H
Postby Lefty64 » Thu Nov 22, 2012 8:55 pm
My van isn't plylined.
I don't have condensation on the floor which is carpeted, or the bare sides, but moisture always condenses on the metal ceiling in wet or freezing weather.
The only remedy is to stop breathing I guess. That'll sort it.
2007 T230LX LWB (110PS) with aircon.
Vans are designed for people with imagination. Cars are so limiting ... what can you do with them?
Lefty64
Postby paul2012 » Thu Nov 22, 2012 9:49 pm
Check to make sure there's no water ingress when it rains :idea:
Common cause is seal around pollen filter / blocked drainage holes & split door seals
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Capovan » Thu Nov 22, 2012 9:54 pm
Thanks for replies, condensation happens overnight when parked up but suppose i will insulate the whole of interior and put some accoustic carpet down etc
cheers
Capovan
Postby Capovan » Thu Nov 22, 2012 9:57 pm
Meant to add its dripping from roof of van in rear not in cabin which is dry as a bone - no leaks etc
Ta
Capovan
Postby Graham Taylor » Thu Nov 22, 2012 10:06 pm
Mine is also soundproofed and sides fitted with acustic covering.
Graham Taylor
Postby Adam_84 » Fri Nov 23, 2012 10:08 am
I get exactly the same issue, condensation on the roof in the load area and when it's freezing cold it freezes and then drips down. Tempted to try and put some of the foiled bubble wrap stuff to the roof and see if that helps.
Adam_84
Postby Capovan » Fri Nov 23, 2012 8:31 pm
I see your in north east graham, did you get the accoustic carpet locally :?:
cheers
Capovan
Postby Graham Taylor » Fri Nov 23, 2012 10:29 pm
Capovan wrote:I see your in north east graham, did you get the accoustic carpet locally :?:
cheers
Bit lower than NE I'm at the top of Lincolnshire. Sent ebay link in PM to the type of stuff I used.
Graham Taylor
