lack off power
lack off power
Postby pauliil1948 » Fri Dec 07, 2012 12:04 am
hi my wee transit 55 plate has lost some power starts fine and runs fine ,for about a mile then starts to hold back a bit ,dose not stutter on miss fire runs good just lacks the boost when it cools down, start driving full power again then about a mile does the same again,on a gradual hill on the motorway i have to change down when i shouldent have to someone sugested turbo boost sensor ,its been servised new filters no change ,thanks for any help iam stuck with no idea ,paul.
pauliil1948
Re: lack off power
Postby liteace » Fri Dec 07, 2012 12:13 am
Get a diagnostics plugged in, look for fault codes and at live data and you should find the problem
liteace
Re: lack off power
Postby pauliil1948 » Sat Dec 08, 2012 12:05 am
Thanks mate will get local garage to check cheers.
pauliil1948
