Front fog light loom
Postby BIG E » Sat Dec 08, 2012 3:50 pm
I'm looking to wire the fogs up in my front bumper and was wondering if there is a loom available for the Connect. My vans got a/c and e/w so thought it maybe just a plug in job as the main loom might be already wired to accept the fog light loom and just need the addition of a relay and switch. Do any of you know where the relay goes and if my van may or may not be wired from the factory to accept the fog light loom? Just another quick question while i'm asking so many others is will a Focus light switch fit or is the switch i need specific to the Connect.My vans a 220 if that helps.
Thanks in advance
Ian
BIG E
Re: Front fog light loom
Postby g-man » Sat Dec 08, 2012 5:10 pm
you'll have to take the bumper off too see if the looms there, light switch is different
g-man
Postby BIG E » Sat Dec 08, 2012 6:26 pm
Thanks for the reply cheif.I seem to remember when i did the bumper swap there was a loom on the passenger side chassis leg with a 4 pin plug on the end that had nothing plugged into it. Is this the loom i'm looking for matey?
BIG E
