Squealing noise...pump?
Postby sparkieno1 » Sat Dec 15, 2012 4:19 pm
Hi, i bought my connect about 4 weeks ago. ive noticed a kind of squealing noise. it possibly sounds like a pump. its high pitched and kind of goes up and down but disappears when revved slightly. sounds like its coming from the middle of the dash but when i lift the bonnet the engines so noisy i cant hear it. any ideas?
sparkieno1
Re: Squealing noise...pump?
Postby blue estate » Sat Dec 15, 2012 4:22 pm
Have you changed the aux belt ? as the noise may not be the fuel pump as it's at the front but could be the pas pump as that's at the rear
blue estate
Postby sparkieno1 » Sat Dec 15, 2012 4:30 pm
ive not changed anything yet, i thought maybe the pas pump but i've not had a chance to have a good look at it. i don't know much about the vans but i can do basic mechanics, servicing and clutches etc. I'll try and have a look tomorrow
sparkieno1
Postby blue estate » Sat Dec 15, 2012 4:36 pm
Try a new belt frist ,as it could just be the belt is knackered
blue estate
Postby sparkieno1 » Sat Dec 15, 2012 4:38 pm
ok cheers, whats involved in changing it?
i should've said, its the tdci engine
sparkieno1
Postby sparkieno1 » Sat Dec 15, 2012 4:52 pm
just went out and had a listen again, it definatly sounds like a pump thats struggling to run, i'll try and have a look at the pas pump tomorrow. cheers
sparkieno1
Postby TIMO » Sat Dec 15, 2012 4:58 pm
belt tensioner and idler pulley bearings wear dry,, they squeel and chirp summat rotten PITA ,, i never cured mine fully .
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
