cluster lights 56 1.8td T200L
Postby PetFt@aol.com » Tue Dec 18, 2012 4:45 pm
Cluster lights will come on and flash and will not stop till i disconnect the battery, take battery lead off and leave for an hour or so all is ok, until i drive sometimes an hour or so then it goes haywire again, clicking from relay under passengers feet,removed and clicking noise stops, but cluster still flashing, no intermittent wipers and interior light flashes when switched on, rev counter, speedo, fuel and temp all stick where they were when fault occurs
PetFt@aol.com
Re: cluster lights 56 1.8td T200L
Postby PetFt@aol.com » Sat Dec 29, 2012 5:45 pm
PetFt@aol.com wrote:Cluster lights will come on and flash and will not stop till i disconnect the battery, take battery lead off and leave for an hour or so all is ok, until i drive sometimes an hour or so then it goes haywire again, clicking from relay under passengers feet,removed and clicking noise stops, but cluster still flashing, no intermittent wipers and interior light flashes when switched on, rev counter, speedo, fuel and temp all stick where they were when fault occurs
help,help,help
PetFt@aol.com
Postby Brains_transit » Sat Dec 29, 2012 6:10 pm
Is the battery in good condition
Brains_transit
Postby Mylee » Sun Dec 30, 2012 1:40 am
Check the smart charge lead. Triangular plug from the alternator, wires run along the rad under the battery and off towards the ecu. Comman fault that the wires break, replacement loom is available from your stealer for about £20
Mylee
Postby PetFt@aol.com » Sun Dec 30, 2012 11:05 pm
Brains Mk6 transit wrote:Is the battery in good condition
Yes battery showed 16v on tickover and 12 with engine off
PetFt@aol.com
Postby PetFt@aol.com » Sun Dec 30, 2012 11:07 pm
Mylee wrote:Check the smart charge lead. Triangular plug from the alternator, wires run along the rad under the battery and off towards the ecu. Comman fault that the wires break, replacement loom is available from your stealer for about £20
Wil look at that tommorow first thing,too late tonight, thanks
PetFt@aol.com
Postby PetFt@aol.com » Mon Dec 31, 2012 8:56 pm
Hi,had a look at cable from alt to up over rad seems ok, took earth lead off for about five min, put back on all o.k, taken for a drive after about 10 miles fault back on again :( looks like its to my local ford. cheers, can anyone tell me where the ECU is on these vans
PetFt@aol.com
Postby valetech » Mon Dec 31, 2012 10:42 pm
:shock:
Your over charging at 16volts
14.4 is about right
molested by:
19s is how we roll
valetech
Postby Altransit » Mon Dec 31, 2012 10:49 pm
16v is a bit high, on charge, and 12v is a bit low, off charge :?
Postby PetFt@aol.com » Wed Jan 02, 2013 10:02 pm
Thanks guys, auto elect coming tomm will let you know how i get on
PetFt@aol.com
Postby PetFt@aol.com » Sun Jan 13, 2013 8:03 pm
PetFt@aol.com wrote:Thanks guys, auto elect coming tomm will let you know how i get on
Elect came and took cluster away came back all still the same, i renewed smart charge loom still happens but not as much (i dont think) next step take off smart charge loom and give terminals a good clean. :?:
PetFt@aol.com
