Sound system help
Sound system help
Postby Lmalone » Wed Dec 26, 2012 9:13 pm
I hvmave fitted a double din alpine stereo in my connect (2005) and the ford speakers am was rubbish so I bought some alpine 13cm speaker fitted them and there not better I want good sound but don't want have a sub... Any suggestions ?
Lmalone
Re: Sound system help
Postby robbie.cee » Wed Jan 02, 2013 2:38 pm
Honestly, out ford stereo back in and turn up bass...
My expensive Sony 4 x 50wrms stereo had no bass compared to the cd6000..
Nuts eh.
Defo recommend some rear speakers too, in boxes or doors will add some thump!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Lmalone » Wed Jan 02, 2013 9:43 pm
robbie.cee wrote:Honestly, out ford stereo back in and turn up bass...
Nuts eh.
It's wired how the ford stereo is better than a alpine stereo but it is :x
Lmalone
Postby markspark71 » Wed Jan 02, 2013 10:15 pm
Make sure the pozz and neg going to the speakers are the right way round as if they aint you will loose quality
What speakers did you buy (code)
markspark71
Postby Lmalone » Wed Jan 02, 2013 10:48 pm
markspark71 wrote:Make sure the pozz and neg going to the speakers are the right way round as if they aint you will loose quality
Which is positive? I just stuck them on and didn't think
Lmalone
Postby markspark71 » Wed Jan 02, 2013 10:58 pm
swap the wires over on one side of the van and see which side sounds the best its that long since i messed with connect spekers i cant remember
markspark71
Postby Lmalone » Wed Jan 02, 2013 11:02 pm
markspark71 wrote:swap the wires over on one side of the van and see which side sounds the best its that long since i messed with connect spekers i cant remember
I might just wack an amp on them and have done with it :o
Lmalone
Postby markspark71 » Wed Jan 02, 2013 11:06 pm
an amp wont make it sound any better it will just make it louder whatis the model number of the speakers your using
markspark71
Postby Lmalone » Wed Jan 02, 2013 11:27 pm
They are the standard ford ones in an 05 I was going to use sound matting in doors put some planet audio speakers in and planet audio amp 8)
Lmalone
