when i say COMPLETE i mean it,it has all the parts needed to change from drum brakes to discs.
contains:-
2x rear stub axles
2x rear calipers with nearly new pads
2x nearly new discs (NO WEAR JUST SURFACE RUST)
1X new handbrake cable swb or lwb
2x splash guards
2x abs sensors (if needed)
discs need a bit of sandpaper to clean off the surface rust (i will do this)
please note you do not get the axle or leaf springs
you will also get any help needed to fit this kit over the phone, email or if nearby can pop in
will also fit vans with and without abs
£200.00 inc p+p
