Changed temprature sender but still a problem
Postby Lmalone » Thu Jan 03, 2013 5:10 pm
Changed temprature sender today but the pin when the van is of drops about a cm under the cold mark and when warms up is just above cold! Do you think the pin need taking of and putting on correctly
Lmalone
Re: Changed temprature sender but still a problem
Postby taz666 » Thu Jan 03, 2013 9:04 pm
is the engine actually getting to running temp?, maybe the thermostat is stuck open :idea:
taz666
Ford Technician
Postby Capovan » Thu Jan 03, 2013 9:08 pm
" the pin " you mean the needle on temp dial. shouldn't need to be moved unless its been moved wrongly before !! or gauge not getting proper info or faulty gauge.
Capovan
Postby jonconnected » Thu Jan 03, 2013 9:34 pm
iv got a problem with the needle on the temp gauge and the rev counter needle also, i think the problem with mines is to do with the speedo unit. i can take the speedo clocks and gauges out and reset the needles to where they should be, then put them back in and when i turn the key to start the engine the needles moves below the place where they should sit, each time i start the van those needles move down abit more and i end up with them so far down i dont get a reading lol on the rev counter when i start the engine it should sit below the 1000 revs but it sits at zero when the engine is just ticking over, when i bought the van it worked fine until i took the unit out to clean it and noticed straight away when i put the unit back in place. :oops:
jonconnected
Postby whitemice » Thu Jan 03, 2013 9:51 pm
Different colour code rings on sensors give different resistances, your new one has too much resistance by the sounds of it.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby Lmalone » Thu Jan 03, 2013 10:32 pm
This is what the dial is doing
Engine just started(cold)....
http://instagr.am/p/UCWeEXioW6/
Engine after a good 30minute run....
http://instagr.am/p/UCWpU4CoXM/
Before new sensor went in it did nothing at all
Lmalone
Postby jonconnected » Thu Jan 03, 2013 10:47 pm
i think its to do with the gauge, my gauge is the same but the needle is sitting much lower down on the reading..
jonconnected
