Transit connect sport
Postby tante » Mon Jan 07, 2013 12:08 am
When I start the van from cold the foot pedal fine but when it's warm up a bit it seem when I press my foot down the van slow taking off could this be a pedal fault it had one already under warranty or could this be the remap?
tante
Re: Transit connect sport
Postby dannysconnect » Wed Jan 09, 2013 11:59 pm
New air filter maybe?
Car Van servicing, diagnostics & Electrical
Cover Berks and Bucks and West London area
dannysconnect
Postby lightning » Fri Jan 11, 2013 7:55 pm
My 110ps was remapped by Superchips and it was never really 100% right.
I was told the Delphi system on the 110 TDCi is a right sod to tune.
Some times it pulled away slowly as if the power was being limited or the turbo was not working. Other times it felt faster than standard, while next time it did not.
In the end I gave up and put it back to standard.
lightning
Postby paul2012 » Fri Jan 11, 2013 8:30 pm
The 110ps TDCI engines normally have the Delphi pumps fitted along with Siemens electronic injectors (common rail)
& the 75 & 90ps TDDI engine have the Bosch VP30 pumps
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby dieselboy1978 » Fri Jan 11, 2013 9:45 pm
Actually that is incorrect.
Mk1 tdci have Delphi common rail system.
Mk1 tddi have a Bosch Vp29/30 fuel pump with Delphi Injectors.
Mk2 tdci have Siemens common rail. Not delphi pump and siemens injectors.
Bank account emptied by
DELPHI
dieselboy1978
