by nyron gaf » Mon Jan 14, 2013 3:04 pm
Hi there everyone, quite new to this site, having throttle issues. Bought a connect t200 08 plate content about 4 months ago, when I test drove, seller pointed out that there was an issue when u throttle it, gets up to about 2500rpm then loses power, then intermittently catches bac up, for May b a good couple of month it was fine, problem seemed to go away, however, last week problem came back, even worst than before, after searching then forum, I noticed a lot of replies saying try the throttle pedal, so at the cost of £96.80, I bought a new pedal tried it and its still doing exactly the same thing, even in neutral when I rev it loses power and the needle drops down, also I've noticed that since the problem came bac the temp gauge doesn't seem to go up much, not sure if this to do with me not being able to throttle it more, not sure what to do next, please if anyone can help or point me in the right direction, best regards, Nyron
