Transit Connect Faults & Fixes list !
Postby paul2012 » Mon Feb 04, 2013 2:23 am
I have not seen a thread for the faults on connects & fixes, (TSB)
So I have started one :wink:
It may prove usefull 8)
5/6/03 Occasional failure or erratic operation of the windshield wipers
Windshield wipers occasionally operate erratically or not at all, the probable cause is electrical or mechanical damage at the park position inside the windshield wiper motor. To rectify this concern, install a revised windshield wiper motor and adjust the position of the windshield wiper arms.
3/26/03 Wind noise from the sliding door, water entering over the sliding door seal, adjustment of the gaps at the sliding door
Wind noise from the sliding door and/or water entering over the sliding door seal, the probable cause is incorrect adjustment of the sliding door. Adjusting the gaps and also the distance the door stands proud / is inset at the top and bottom.
2/12/10 Accessory drive belt noise, failure of the charging system; Flat battery
Accessory drive belt noise, failure of the charging system or a flat battery the probable cause is an generator decoupler shaft failure.
To rectify this concern, the generator decoupler shaft should be renewed. It is NOT required to install a new generator.
If the generator decoupler shaft is not cause of this concern, refer to the diagnostic and testing
8/26/11 Grinding noise from the front end during straight-ahead driving and when cornering; Installation of a new halfshaft bearing
Grinding noise from the front end during straight-ahead driving and when cornering, the probable cause is a defective halfshaft bearing.
To rectify this concern, the intermediate shaft should be removed and a new halfshaft bearing and halfshaft bearing retainer installed.
When holding the halfshaft bearing retainer and rotating the bearing, a rough feel should clearly be felt. With the vehicle raised, turn the halfshaft via the wheel and listen for grinding noise or rough running of the halfshaft bearing for this purpose.
7/8/05 Grinding noise from the front end during straight-ahead driving and when cornering; Installation of a new halfshaft bearing
Grinding noise from the front end during straight-ahead driving and when cornering, the probable cause is a defective intermediate shaft center bearing. To rectify this concern, the intermediate shaft must be removed and a new intermediate shaft center bearing and center bearing retainer must be installed.
When holding the intermediate shaft center bearing retainer and rotating the bearing, a rough feel should clearly be felt. With the vehicle raised, turn the halfshaft via the wheel and listen for grinding noise or rough running of the intermediate shaft center bearing for this purpose.
11/30/05 Transmission noise or knocking, scratching noise from behind the engine rear mount
Transmission noise or knocking, scratching noise (knocking, scratching noise from behind the engine rear mount, occurs especially with the engine at operation temperature after abrupt gear changes, acceleration in 2nd gear or during rapid acceleration in 1st or reverse gear), the probable cause is an insufficient clamping force of the engine support insulator to subframe bolt owing to tolerances being exceeded. Failure of the rubber insulator will allow the normal acceptable Noise, Vibration and Harshness (NVH) levels to be transmitted to the subframe and body structure. The noise cannot be reproduced with the vehicle stationary or when raised on a vehicle lift. Please make sure the engine support insulator is inspected before any parts are renewed.
To rectify this concern, the engine support insulator has to be removed, inspected and if there are witness marks on the isolator due to contact a new engine support insulator and a new engine support insulator to subframe bolt should be installed. If there are no marks indicating contact, install the original engine support insulator and continue the diagnosis.
11/30/09 Waterleaks at the upper windshield
Waterleaks from the upper windshield area with heated windshield, one probable cause is insufficient application of windshield adhesive during production.
To rectify this concern, windshield adhesive should be applied into the gap at the windshield. It is NOT required to install a new windshield.
To enable a smooth adhesive application the grey flat nozzle needs to be reworked.
9/3/09 Inoperative or unintended blower motor operation
Blower motor is inoperative or operates independently of the position of the blower speed control switch, the probable cause is contact between the blower speed control switch wiring and the instrument panel bracket. This may affect one or more of the single wires causing the blower motor to not operate properly.
To rectify this concern, the damaged single wires should be repaired, re-routed and fixed with a cable tie ensuring sufficient distance away from the instrument panel bracket.
3/25/09 Growl noise and excessive vibration in the passenger compartment, clearly noticeable between 2600 and 3000 rpm
Growling noises and excessive vibration in passenger compartment, clearly noticeable between 2600 and 3000 rpm, the probable cause is the engine vibration being transmitted into the vehicle body through low pressure side rubber refrigerant hose (between the A/C compressor and A/C accumulator).
To rectify the concern, a damper mass should be attached onto the refrigerant hose specified location
7/4/07 Sliding door lock cannot be locked or unlocked via the central locking
Sliding door lock cannot be locked or unlocked using the central locking (with the vehicle key or with the remote control), the probable cause is a damaged sliding door lock assembly or poor sliding door alignment. To rectify the concern, the central locking and the door ajar switch should be checked and, if necessary, door alignment should be corrected or a new sliding door lock assembly and a new wiring harness to the actuator motor should be installed.
10/18/04 The sliding door lock cannot be locked or unlocked via the central locking
7/2/07 Rear doors cannot be locked or unlocked via the central locking; Rear door lock is inoperative and/or mechanism is seized
Rear doors cannot be locked or unlocked via the central locking or the rear cargo door lock is inoperative and/or mechanism is seized, the probable cause is a bent release lever or jammed door handle reinforcement.
6/29/07 Engine does not start; Starter motor does not crank
Engine does not start or the starter motor does not crank, the probable cause is a damaged circuit wire on 14K733 wiring harness under certain circumstances in the vicinity of connector C120 attached to battery tray.
To rectify this concern, the affected wiring harness has to be checked and a damaged wiring/insulation has to be repaired as required. To prevent further touch condition the installation position of connector C120 has to be attached to the battery tray using a cable tie.
6/5/09 No Start, poor driveability, black smoke and high fuel consumption
No start, poor driveability, black smoke, high fuel consumption, and other potential root causes have been eliminated (fuel quality, Exhaust Gas Recirculation (EGR), fuel line blockages, etc), the injectors may need to be investigated.
9/1/05 Engine undershooting to a stop, lack of power resulting in reduced top speed, hesitation or failure to start
Engine undershooting to a stop, lack of power resulting in reduced top speed or failure to start, one of the the probable causes is cam plate failure in the Bosch VP30 fuel injection pump, caused by contamination of the fuel system. To rectify this concern, a new fuel injection pump, fuel injectors and high pressure fuel supply lines should be installed, the fuel system thoroughly cleaned and a fuel additive should be used.
Failures will occur due to: Water in fuel. The capacity of the water trap in the fuel filter is around 100ml. Should a poor fuel quality supply be used or service intervals missed, the water trap will become inadequate. The water in the fuel will cause corrosion inside the fuel injection pump and lack of lubrication, which will lead to damage of the highly loaded cam plate and cam plate rollers. Petrol in the fuel. The cam plate and cam plate rollers being the highest loaded components in the fuel system need good lubrication, hence if petrol is in the fuel, wear of all components needing lubrication will occur. Failure of the cam plate can also lead to failure of the fuel injection pump front seal. This will allow diesel fuel to enter the sump and potentially cause catastrophic engine damage.
4/26/07 Oil leakage from the clutch master cylinder; Clutch does not function when clutch pedal is depressed or clutch pedal stays depressed when clutch pedal is released
Oil leakage to the driver footwell and that the clutch does not function when clutch pedal is depressed or the clutch pedal stays depressed when the clutch pedal is released, the probable cause is the clutch master cylinder piston surface being damaged due to the dust and dirt ingress.
To rectify this concern, a new clutch master cylinder and a rubber protective boot should be installed to prevent dust and dirt ingress.
1/31/07 Brakes binding when the brake pedal is not being depressed
Slight braking is occurring when the brake pedal is not being depressed and/or rattling noise from the brake pedal bracket is occurring when the brake pedal is being depressed, the probable cause is incorrect position of the retractor mechanism. Misalignment of the retractor mechanism hole and the body aperture causes the brake pedal to bind. To rectify this concern, the brake pedal retractor should be removed and the hole in the retractor mechanism reworked to a larger diameter leaving no less than 3 mm of material. a squeak or rattling noise is occurring from the brake pedal box when the clutch pedal is depressed or during cornering when the clutch pedal is not depressed, the probable cause is the clutch pedal return spring retainer being fractured. To rectify this concern, a new clutch pedal return spring and retainer should be installed.
4/22/03 Brakes binding
Slight braking is occurring when the brake pedal is not being depressed, the probable cause is incorrect position of the retractor mechanism. Misalignment of the retractor mechanism hole and the body aperture causes the brake pedal to bind. To rectify this concern, the retractor mechanism should be removed and the hole in the retractor mechanism reworked to a larger diameter leaving no less than 3 mm of material.
10/2/06 Noises and/or vibration from the front suspension
Noises and/or vibration coming from the front suspension the probable causes are
cupping on tires, halfshaft problems, front wheel bearings and wheel hub retaining nut failures.
4/22/03 Knocking noise from the rear under braking
Knocking noise coming from the rear under braking, the probable cause is a tolerance mismatch between the wheel spindle and the back plate. To rectify this concern, the wheel spindle should be reworked by chamfering the sides.
6/11/07 Knocking noise from the rear when braking
Knocking noise coming from the rear when braking, the probable cause is a tolerance mismatch between the wheel spindle and the brake back plate. To rectify this concern, for vehicles built up to 20.04.2007 first drive the vehicle at maximum 15 mph in first gear for 250 meters with handbrake applied 3 notches, wait for 15 minutes and carry out a road test to verify. If the concern still exists, then interchange the left hand and right hand brake drum and perform parking brake cable adjustment and carry out a road test to verify. If the concern still exists, then rework the wheel spindle by chamfering the sides and install new brake back plates. Perform parking brake cable adjustment again and carry out a road test to verify.
For vehicles built after 20.04.2007, first drive the vehicle at maximum 15 mph (20km/h) for 50 meters forward direction with handbrake applied in 3 notches and before releasing the handbrake lever, drive backwards under the same condition. Wait for 15 minutes and carry out a road test to verify.
9/6/07 Condensation dripping into the front footwell
Dampness in the front footwell the probable cause is incorrect manufacturing tolerances in the joints of the climate control housing components. This allows condensation to escape from the bottom corner of the climate control housing when the air conditioning (A/C) is operating.
To rectify this concern the climate control housing should be removed and sealing strip applied to the gaps in the climate control housing joint area.
Before carrying out the procedure detailed in this bulletin eliminate all other possible causes for water entry into the front footwell (e.g. water entry after passing through a car wash, during very heavy rain or because of a blocked A/C overflow hose on the bulkhead in the engine compartment). Additionally the A/C system should be tested.
9/14/07 Water ingress in the front footwell/interior and in the loadspace
Isolated instances of the following causes of possible water ingress points in the front footwell/interior have been identified:
A. Water ingress via the drain bore in the water trap or via the windshield (left-hand vehicle side):
Cause: Insufficient or intermittent sealer applied in production between the fender apron panel outer reinforcement and the A-pillar/water trap may lead to water entering into the front footwell. To rectify: Seal the affected areas with sealer. Installing a new windshield and a new windshield glass weatherstrip is not necessary. Cause: Water may enter into the front footwell between the windshield and the windshield frame because of insufficient or intermittent sealer applied in production. To rectify: Seal the affected areas with sealer. B. Water ingress via the fender apron panel outer reinforcement (right-hand vehicle side):
Cause: Water can enter the front footwell between the fender apron panel outer reinforcement and the grommet because of insufficient or intermittent sealer applied in production. To rectify: Seal the affected areas with sealer. C. Water ingress via the pollen filter housing:
Cause: Water can enter the front footwell via an excessively large gap between the pollen filter housing and the cowl panel grille as well as certain body joints. To rectify: Seal the affected areas with sealer. D. Water ingress via the liftgate/rear door weatherstrips:
Cause: The adjustment of the right-hand door check arm, a hardened blanking plug on the D-pillar, an incomplete seal at the liftgate hinges or an inadequately-installed door weatherstrip can result in water ingress in the rear section of the loadspace. To rectify: Adjust the door stop, install a new cover plug, correct the position of the rubber seal on the rear door. E. Water ingress via the C-pillar in the area of the sliding door:
Cause: Water can enter the interior between individual body parts of the sliding door guide because of insufficient or intermittent sealer applied in production. To rectify: Seal the body parts of the sliding door guide from the interior using additional sealer. F. Water ingress via the roof rack blanking plugs and the ventilation flaps:
Cause: Water can enter the interior via a deformed blanking plug bore, missing or damaged roof rack blanking plug seals or via the ventilation flaps in the rear section of the vehicle roof. To rectify: Remove the blanking plugs and install new roof rack blanking plug seals. Install new ventilation flaps. G. Water ingress via the sliding door:
Cause: Water can enter the interior via a damaged watershield and an inadequate seal at the upper sliding door guide. To rectify: Install a new watershield and seal the upper sliding door guide with additional sealer. H. Water ingress via the rear side windows:
Cause: Water can enter the interior via an incorrectly-installed rear quarter window glass weatherstrip. To rectify: Correct the installation position of the rear quarter window glass weatherstrip and seal with additional sealer. I. Water ingress via the rear door central high mounted stoplamp:
Cause: The stoplamp opening on the rear cargo door outer sheet metal is out of tolerances causing insufficient seal area.
8/8/06 Increased coolant temperature and oil residue in the cooling system in combination with leaks in the engine oil cooler
Increased coolant temperature leaks at the engine oil cooler oil residue in the cooling system coolant expansion tank the probable cause is an internal leak in the engine oil cooler.
To rectify the leaks at the engine oil cooler a modified oil cooler and oil filter housing should be installed.
To rectify the oil residues in the cooling system, the cooling system should be drained, the coolant thermostat should be removed, the cooling system should be flushed and new coolant hoses and coolant expansion tank installed.
3/27/06 Replacement of the accessory drive belt tensioner bracket or the idler pulley
Because of damage to the threaded hole during the re-tightening process, the pulley located on the tensioner bracket (Part Number: F1351134) should NOT be removed. The pulley is NOT a serviceable part and does not have a part number.
The accessory drive belt pulley retaining bolt must NOT be unscrewed/re-tightened. The tensioner bracket MUST be replaced as a COMPLETE unit. Because of damage to the threaded hole during the re-tightening process, the retaining bolt may become loose and cause total loss of the Accessory Drive hence the tensioner bracket MUST be replaced as a COMPLETE unit. Removing and installing the pulley may cause damage resulting in failure.
1/30/06 Anti-lock braking system (ABS) warning lamp illuminating in the instrument cluster
ABS warning lamp is illuminating on the instrument cluster, the probable cause is a touch condition between the ABS module wiring and the transmission shifter mass, resulting in a damaged ABS module wiring. To rectify this concern, the ABS module wiring has to be checked and a damaged wiring/insulation has to be repaired as required. To prevent further touch condition the ABS module wiring has to be attached to the brake tube using two cable ties, creating a minimum clearance of 20 mm between the ABS module wiring and the transmission shifter mass (reverse gear engaged).
1/16/06 Poor gear shiftability, difficult changing gear or transmission jumping out of gear
Difficulties in changing gear or a transmission jumping out of gear, the probable cause is contact between the power steering hoses and the transmission external controls. The power steering lines are loose/saggy and stick with the transmission shifter mechanism.
Before performing any repair work on the inner selector mechanism or the gear shift cables and before the adjustment of the gearshift cables is checked, the routing of the power steering lines has to be changed.
10/13/05 Unable to engage gear, disengaged gearshift cable from the shift lever
Unable to engage a gear, the probable cause is a disengaged gearshift cable. To rectify this concern, a new gearshift cable retainer and a new spring must be installed.
11/4/05 Noise from the fuel tank area and damaged fuel tank support straps
Excessive noise from the fuel tank area issue with possible damage to the fuel tank support strap, the probable cause is insufficient grip of the fuel tank straps, creating a clearance between fuel tank and vehicle body.
To rectify this concern, new fuel tank noise, vibration and harshness (NVH) pads and/or new fuel tank support strap should be installed.
4/21/05 Speedometer fluctuating; engine difficult to start; loss of power; radio losing volume
Following concerns: Speedometer fluctuating Engine difficult to start or running rough Loss of power when descending long inclines, clutch is depressed or under braking Radio losing volume the probable cause is the powertrain control module (PCM) error detection system incorrectly diagnosing the vehicle speed sensor (VSS) signal. This leads to the vehicle displaying a diagnostic trouble code (DTC) showing the VSS as defective. To rectify this concern, the VSS should be correctly diagnosed as defective prior to installing a new one.
8/17/05 Poor power; delayed accelerator response and/or rough idle, engine hard or impossible to start
Poor performance Delayed throttle response Rough idle or hard to start and WDS checks reveal that either diagnostic trouble code (DTC) P0340 or P0335 is set, the probable root cause is a loss of signal from the CMP sensor. To rectify the concern, a new CMP sensor and electrical connector should be installed as required.
Due to various changes to the CMP sub-system throughout the listed products program cycles, it is necessary to make sure that the wiring loom side electrical connector is compatible with the CMP sensor in the event of a new CMP sensor being installed.
3/9/10 Delayed reaction of fuel gauge on the instrument cluster after fuel tank refilling
fuel gauge is delaying to respond after fuel refillling, the probable cause is a software failure of the instrument cluster.
To rectify this concern, the instrument cluster should be reprogrammed with updated software.
3/11/11 Water ingress into the interior; Windnoise from the front door; Upper front door weatherstrip loose or comes adrift on the A-pillar sheet metal
Water ingress into the interior, windnoise from the front door or that the upper front door weatherstrip becomes loose or comes adrift on the A-pillar sheet metal, the probable cause is poor installation of the weatherstrip in conjunction with minor adhesion of the adhesive strip.
To rectify this concern, the affected upper front door weatherstrip should be renewed. To improve the adhesion primer should be applied to the installation area.
4/3/03 Production changeover from tin plated to gold plated connector pins on the fuel temperature sensor on the high pressure pump; installing a new high pressure pump
Since 24.10.2002 there has been a change in production from tin plated to gold plated connector pins on the fuel temperature sensor on the high pressure pump for Focus and Transit Connect with 1.8L DuraTorq-TDCi engine (90/100/115PS), with common rail fuel injection system.
Since 24.10.2002 only the high pressure pump together with a partial wiring harness with gold plated connector pins has been installed. Making a connection between tin plated connector pins and gold plated pins in the wiring harness socket is NOT permitted.
If a new high pressure pump or partial wiring harness of the high pressure pump must be installed, make sure that both components either have only tin plated or only gold plated connector pins.
The high pressure pumps can be identified by the colour of the fuel temperature sensor.Fuel temperature sensor (green) - tin plated connector pinsFuel temperature sensor (blue) - gold plated connector pins.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: Transit Connect Faults & Fixes list !
Postby markspark71 » Mon Feb 04, 2013 6:18 pm
Some good info there m8 should be a sticky
markspark71
Postby highroof » Tue Feb 05, 2013 12:00 am
Bored or not, great post, agreed, it should be a sticky.
highroof
Postby paul2012 » Tue Feb 12, 2013 10:25 pm
More Fixes :D
8/11/10 Fuel injection pump on 1.8L Duratorq-TDCi (Lynx) Diesel service engines equipped with the crankshaft timing sprocket belt-in-oil system
On vehicles with Lynx diesel series build from 10/2007 onwards the crankshaft timing sprocket which drives the fuel injection pump sprocket by means of a chain drive has been changed to the belt-in-oil system.
1.8L Duratorq-TDCi (Lynx) Diesel service engines with Siemens fuel injection pump will be delivered with the new belt-in-oil system only.
3/7/11 Inaccurate readings from the outside air temperature sensor until system comes to steady state condition after engine startup
Outer air temperature displayed on the instrument cluster is inaccurate, the probable cause is the long time period necessary for the sensor to start correct readings from outside. This appears until system comes to steady state after engine startup.
To rectify this concern, a new outer air temperature sensor has to be installed. Furthermore the calibration for the instrument cluster should be updated to the latest level.
10/21/11 Metallic noise from the front spindle carriers when pulling away in 1st gear or reversing
Metallic noise coming from the front spindle carriers when pulling away in 1st gear or reversing, the front axle half shaft should be partially removed from the spindle carrier on both sides and sealant applied to the splines.
Drying time for the sealant at room temperature is 1.5 hours
Fuel gauge is delaying to respond after fuel refillling, the probable cause is a software failure of the instrument cluster.
5/16/03 Loud noises when opening and shutting the double rear doors; damaged check strap on the double rear doors
Loud noises when opening and shutting the double rear doors or that the check strap on the double rear doors is damaged, the probable cause is a faulty guide arm in the check strap or damaged threads in the D-pillar. To rectify the concern, new check straps should be installed on both rear doors.
8/15/03 Rear right-hand door cannot be opened from the inside nor from the outside; detached door handle to unlatching rod connection
Rear right-hand door cannot be opened from the inside nor from the outside, the probable cause is a detached door handle to unlatching rod connection (directly beside the yellow unlatching handle). To rectify the concern, the right-hand rear door trim should be removed, any damaged or detached components removed from the door and a revised clip with a two sided retaining pin should be installed on the door unlatching mechanism.
8/6/09 Oil leak from the oil sump
In the event of oil leaks at the oil sump, the probable cause may be torque loss on one oil pan retaining nut/stud on the flywheel side.
re-tighten the stud on the flywheel side and to apply the silicone sealant all around the stud.
paul2012
Postby paul2012 » Tue Apr 02, 2013 3:25 am
markspark71 wrote:Some good info there m8 should be a sticky
I agree there :wink:
As several of these faults have been mentioned recently :(
paul2012
Postby millertime_1985 » Fri Jun 14, 2013 8:19 pm
i'll offer up the following problems...
# Spare wheel carrier on the underside on the vehicle, with little/no protection from road spray and/or road salt... meaning the mechanical aspect of the device isn't all that reliable.
# Holes in the rear chassis with no optional covers to reduce amount of moisture and salt getting in at the nuts and bolts for holding the rear bumper on, making it almost impossible to replace a bumper without having to buy extras from ford (or is that the point)
(i intend to resort to covering the nut access holes with ductape, atleast in the short term)
Its Not a Van..... Its a Transit
millertime_1985
Postby Cresser » Tue Jun 18, 2013 10:23 pm
highroof wrote:Bored or not, great post, agreed, it should be a sticky.
I too think it should be a sticky. There needs to be more sticks for this site. Come on moderators sort it out.
Transit Connect LWB TDdi 75HP 2003. Focus air box mod + EGR blanked.
Cresser
Postby paul2012 » Fri Jun 21, 2013 9:01 pm
UPDATE
The following are for connects from 2009 onwards
09/19/18 Rear door rattle.
Some vehicles may exhibit a rattle noise coming from rear doors. this may be due to metal on metal contact between one or more of the rear door(s) latches and strikers N/S upper latch.
09/19/6 Heater blower fan switch continuous operation/inoperative on one speed.
Vehicles may exhibit a heater blower fan motor continuously operating, or inoperative on one speed setting. this may be due to a wire chafe in the 14401 wiring harness.
09/20/8 Passenger wiper arm interferes with driver arm in park position.
Vehicles built before 7/12/09 may exhibit a touch condition, driver wiper blade to passenger wiper arm contact, when lifting the driver arm up off the windshield.
12/1/14 Vehicles may experience no cold air from air conditioner or vehicle overheating.
This is due to a blown fuse, making electric cooling fan inoperative.
12/11/13 Turn Signal Lamp inoperative,
Lamp socket contact for front turn signal, may exhibit looseness, or distortion, or damage. models 2010-2012 Transit Connect.
12/9/5 Vehicle exhibits lack of or loss of power and run rough or stumble or hesitate,
This is due to possibility of spread terminal 69 and/or 70 in powertrain control module (pcm) connector c1753. model 2012 Transit Connect.
12/1/3 Vehicles exhibit oil leak at the oil filter seal,
Oil filter housing for the oil seal may be distorted.
21/3/20 Front wipers on continuously (unless fuse 146 is removed),
Vehicles may have a short to ground on circuit 15-KA28 that feeds the rear wiper motors. DTC's B2114 or B1439 are stored in the GEM and Instrument panel.
21/8/41 Air bag inicator flashing with a stored trouble code,
Some 2009-2011 models may have Comm-trans lund, this is a software problem. Rectify via WDS.
12-10-9 Wipers fails proper wiping and/or clearing
new and improved, wiper blade and pivot arm replacing old style wiper blade and pivot arm, and not compatible with old style blades and pivot arm. models 2011-2012
Recall Number: 12S36 Recall Date: 08-02-2012 Affected Vehicles: 16,330 Component: windshield wiper/washer
Ford is recalling certain model year 2011-2012 transit connect vehicles. the wiper arms may not be adequately riveted resulting in incomplete or inconsistent clearing of the windshield and possible detachment of the wiper arm.
If the wiper arm detaches, the windshield wiper will fail and the driver's visibility may be reduced, increasing the risk of a crash.
How to Fix:
Ford will notify owners, and dealers will replace the driver and passenger side wiper arm and blade assemblies, free of charge. the safety recall began on august 15, 2012
Recall Number: 10C13 Recall Date: 07-07-2010 Affected Vehicles: 33,728 Component: roof and pillars
Ford is recalling certain model year 2010 transit connect vehicles manufactured from december 5, 2008 through may 31, 2010 for failing to meet the minimum requirements of federal motor vehicle safety standard no. 201,
""occupant protection in interior impact.""
during vehicle testing the vehicle exceeded head injury criteria requirements set by the standard. the headliner retention pushpin located on the headliner above the b-pillar trim on both the left and right side of the vehicles needs to be replaced. In the event of a vehicle crash, an occupant could be at an increased risk of injury.
How to Fix:
Ford will notify owners and dealers will repair the vehicles free of charge. the safety recall began on july 19, 2010.
paul2012
Postby paul2012 » Sat Jun 22, 2013 12:29 am
Update for Connects from 2003-2009
3/9/05 Water entering into the interior; Noises coming from the area of the load space roof opening panel
There have been various concerns where water enters into the interior and over noises coming from the area of the load space roof opening panel:
1. Water entering from the D-pillar upper sheet metal connection points into the interior
Cause: Gap between flanges because of insufficient sealant applied in production. To rectify: Seal the affected areas with clinched flange sealer. 2. Water entering into the interior between the weatherstrips of the load space roof opening panel and the body
Cause: Water can enter the interior because the seal gap is too large. To rectify: Loosen the tail roof opening panel striker screws and move the load space roof opening panel striker upwards to decrease seal gap. 3. Water entering from the sheet metal connection points of the drain channel into the interior.
Cause: Insufficient sealant applied in production. To rectify: Seal the affected areas with clinched flange sealer. 4. Water entering via the weatherstrip on the rear doors into the interior
Cause: Water entering the rear part of the loading space may be caused by an incorrectly installed weatherstrip on one or both of the rear doors. To rectify: Realign the flange angels. 5. Water entering into the interior from the load space roof opening panel watherstrip
Cause: Inadequate sealing of weatherstrip. To rectify: Apply clinched flange sealer to the inside of the weatherstrip. 6. Water entering into the interior from the load space roof opening panel weatherstrip
Cause: Inadequate sealing of weatherstrip. To rectify: Apply clinched flange sealer to the end of the weatherstrip carrier. 7. Water entering the rear part of the loading space from under the flap of the weatherstrip carrier
Cause: Inadequate sealing of weatherstrip. To rectify: Apply clinched flange sealer to the flap. 8. Noises from the load space roof opening panel (only vehicles build up to 05.10.2004 (build code 4Y))
Cause: Load space roof opening panel hinges not robust enough. To rectify: Install new load space roof opening panel hinges. Vehicles built from 06.10.2004 (build code 4Y) onwards have already the new hinges installed.
3/24/06 Rasping or squeaking noises in the interior
There have been various concerns over rasping or squeaking noises in the interior:
1. Creak noise while driving when the front door window is half open.
Cause: Contact between window glass clamp and window glass/window regulator lifting plate. To rectify: Install two new window glass clamps and apply grease everywhere the plastic lifting plate contacts with the rail (vehicles built up to 30.10.2005 (build code 5K) only). For vehicles built from to 31.10.2005 onwards (build code 5K) only grease should be applied everywhere the plastic lifting plate contacts with the rail. 2. Squeak noise from the front door striker area (vehicles built up to 13.05.2005 (build code 5B) only).
Cause: Contact between the front door latch and door striker. To rectify: Adjust the front door latch to the striker. If the concern is still present, install a new front door striker. 3. Rattle and creak noise from the upper rear door striker (vehicles with rear doors built up to 24.12.2005 (build code 5E) only).
Cause: Movement between the rear door latch and the upper striker. To rectify: Adjust the rear door latch to the striker. If the concern is still present, install a new rear door latch. 4. Rattle and creak noise from the rear door striker (vehicles with liftgate only).
Cause: Movement between the rear door latch and the striker. To rectify: Adjust the rear door latch to the striker. 5. Squeak and rattle noise from the tailgate (on both sides) (vehicles built up to 26.05.2005 (build code 5B) only).
Cause: Squeak and rattle noise due to movement of the liftgate caused by side wedges. To rectify: Install new side wedges with new bolts on the left and right side of the liftgate. 6. Squeak noise from the lower A-pillar.
Cause: Squeak noise due to metal to metal touch conditions. To rectify: Rework sheet metal components. 7. Squeak noise from the lower B-pillar (non-sliding door side).
Cause: Squeak noise due to metal to metal touch conditions. To rectify: Rework sheet metal components. 8. Rattle and buzz noise on rough road and when closing front or side door.
Cause: Security shield is moving inside the D-pillar (vehicles with liftgate only). To rectify: Remove the rear lamps and apply sealer between the security shield and the D-pillar sheet metal. 9. Rattle noise on rough road from both sides of the vehicle and when closing front or side door.
Cause: Touch condition between the second row side window glass and the track. To rectify: Apply foam between the second row side window glass and the track.
8/22/05 Cracks at the bottom edges of the windshield
Cracks appearing at the bottom edges of the windshield, the probable cause is a touch condition of the windshield with the sheet metal. In these cases the roof panel and windshield glass locating block holes on the dash panel are out of tolerance.
To rectify this concern, a new windshield glass in combination with additional rubber pads should be installed. The additional rubber pads prevent touch condition between the windshield glass and the sheet metal.
12/5/02 Reduction in windshield washer performance due to trapped windshield washer hose
Reduction in windshield washer performance, despite the pump appearing to operate correctly, the probable cause is a trapped windshield washer hose in the region of the hood hinge. To rectify this concern, the hose should be re-routed.
6/6/05 Uneven tire wear on front tires
Uneven tire wear on the front tires, the probable cause is body manufacturing variables, incorrect front toe alignment or camber values. To rectify this concern, an initial check of the tire wear should be performed to accurately identify the nature of the tire wear. Following this, a check of the front toe alignment and camber values should be carried out and rectified as necessary.
6/6/05 Uneven tire wear on rear tires
Uneven tire wear on the rear tires, the probable cause is body and rear axle manufacturing variables, incorrect rear toe alignment or camber values. To rectify this concern, an initial check of the tire wear should be performed to accurately identify the nature of the tire wear. Following this, a check of the rear toe alignment and camber values should be carried out and rectified as necessary.
7/4/04 Fuel return line sleeve chafing on the timing cover
It is possible that engine vibrations may cause the fuel return line sleeve to chafe in the vicinity of the timing cover. To rectify this concern, a new clip should be installed between the fuel return line and the timing cover.
5/10/04 Rattle noise coming from the front seat tracks
Rattle noise coming from the front seat tracks, the probable cause is missing front seat adjuster locking washers. To rectify this concern, new locking washers should be installed.
1/12/04 Excessive play in fuel tank support straps
It may be found in service that there is excessive movement of the fuel tank causing noise, vibration and harshness (NVH) with possible damage to the fuel tank support straps. The probable cause is the NVH pads coming loose or falling off, creating a clearance between fuel tank and vehicle body. To rectify this concern, revised fuel tank support straps should be installed that do not require NVH pads.
12/4/03 Rattling noise from under the vehicle
Rattling noise from under the vehicle, the probable cause is a detached parking brake cable support bracket. To rectify this concern, new parking brake cable support bracket retaining bolts with revised washers should be installed.
4/24/05 Difficulty removing the rear brake drum
As a result of every day use, the rear brake drum friction surface and brake shoe linings wear out. Over time, a groove is formed on the brake drum friction surface and the brake shoes embed into this as a result of the self adjustment mechanism, creating difficulty in removing the rear brake drum.
To aid removal of the rear brake drums, the procedure in this bulletin should be followed. It is necessary to release the parking brake lever adjustment, then access the parking brake pawl through the rear of the brake backing plate. This then needs to be levered over the edge of the brake shoe, thus releasing the rear brake adjustment.
5/11/06 Intermittent working conditions of fuel fired booster heater
Intermittent working conditions of fuel fired booster heater can lead to early contamination of the glow plug and heating chamber. These failures reduce the working performance of the non programmable fuel fired booster heater.
For a customer paid request, dismantling of the outside air temperature sensor and the installation of the Kit - Fuel fired booster heater including a new timer that will be driven by the customer, will enable the system to function under customer control. This kit should be installed to prevent the excessive smoke related with the intermittent drive conditions of the customer (frequent stop-go situations).
The programmable fuel fired booster heater must not be operated at filling stations. Allow for the extra three minutes of heater operation when refuelling. The location of the timer on the instrument panel should be discussed with the customer.
9/17/06 Activation/deactivation and adjustment of vehicle speed limiter
Transit Connect 2002.5 (06/2002-) dealer configurable speed limiting is available on vehicles with diesel engines. Should a customer request this feature to be activated/deactivated/adjusted, the procedure in this bulletin should be followed.
Transit Connect 2002.5 built from 04.02.2003 (build code 3K) a calibration update is required - Use WDS/IDS CD 45 or a later version.
paul2012
Postby paul2012 » Sat Feb 22, 2014 12:19 am
I will be updating this thread shortly with TSB's for the new Transit Connect (2013 onwards) 8)
paul2012
Postby jimmybones » Mon Apr 28, 2014 7:56 pm
hi all i have a transit conect 1.8 tdci was blowing black smoke from exhaust on acceleration.it a 57 reg gave it a service but still blowing black smoke out sometimes they are quite sooty .had it on the diagnostic machine twice this week only fault that came up was a injecter plug clip had broke so when driving down motorway it was moving fixed that now .every morning on pulling away big spurts of black smoke come out of exhaust then it settles down but when i gwt onto motor way the same thing happens as i increase my speed.it is also using aprox 20 pounds of derv a day for a round trip of 86 miles this is never right.forgot to mention i had a vacume pipe leaking so that was replaced im baffled please help if poss ive tried loads if different trhings but now at a standstill reguards james
jimmybones
Postby celtic0125 » Wed Jul 09, 2014 2:43 pm
Plz help
When i put my blowers on newts comeing out the vents evan on full wack just newt
54plate swb
celtic0125
Postby paul2012 » Wed Jul 09, 2014 7:07 pm
celtic0125 wrote:Plz help
54plate swb
If fan is working then check control cable from airflow control to heater assembly :wink:
paul2012
Postby celtic0125 » Wed Jul 09, 2014 10:21 pm
ill try that 2moz cheers
celtic0125
Postby paul2012 » Fri Jan 16, 2015 8:24 pm
Should this thread be a sticky :?: :?:
paul2012
