rear knocking only when braking
Postby snoopdog247 » Tue Feb 05, 2013 10:28 am
I have a 57 plate transit connect 18 tdc every time the brakes are applied a knocking noise comes from the rear the harder you press the pedal the louder it gets. More noticeable at high speed have tried new drums and shoes and new handbrake cable but still it keeps knocking the brakes seem to be working as they should and the van has recently gone through an mot any ideas to try
snoopdog247
Re: rear knocking only when braking
Postby paul2012 » Tue Feb 05, 2013 8:52 pm
snoopdog247 wrote:I have a 57 plate transit connect 18 tdc every time the brakes are applied a knocking noise comes from the rear the harder you press the pedal the louder it gets. More noticeable at high speed have tried new drums and shoes and new handbrake cable but still it keeps knocking the brakes seem to be working as they should and the van has recently gone through an mot any ideas to try
Check here, Fault has been listed with fix
viewtopic.php?f=54&t=124877
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby snoopdog247 » Wed Feb 06, 2013 8:41 am
THANKS FOR THAT WILL GIVE IT A TRY AND LET YOU KNOW
snoopdog247
