Spraying Interior Plastics
Postby Bottled@Source » Thu Feb 07, 2013 6:01 pm
Has anyone done this on there connect, they grey is so grey....... :?
If so,
Is it an easy job? removal? or just a case of duck taping the inside and going careful? wash down with sugar soap?
What paint spray to use?
I have a load of Black alloy spray (5 cans) would this be to "hard" a paint?
Cheers
Bottled@Source
Re: Spraying Interior Plastics
Postby gt_addict » Thu Feb 07, 2013 6:35 pm
I've been looking at something someone else has used on here to do the arch trims. It's called plastidip. Looks like good stuff but can't find much on preparing te surface and if primer is needed or not.....well I say I can't find much, I haven't really had time to look :lol:
gt_addict
Postby Capovan » Thu Feb 07, 2013 8:39 pm
Try a body shop supplier they will put you right on how to prepare and what to use
Capovan
Postby Adam_84 » Thu Feb 07, 2013 9:27 pm
Pretty sure with plasti-dip you only prime if you want a permanent coating as plasti-dip is designed to be spayed on and then peeled off. Will try and find the info thing
Adam_84
Postby Adam_84 » Thu Feb 07, 2013 9:35 pm
Adam_84
